Old 07-03-2009, 11:08 PM   #13 (permalink)
Fade2black's Avatar
Originally Posted by dredge View Post
Would like a second opinion on the model number to order Axel is the 35 spline dana seventy one.
when i looked it up on randy's ring and pinion a second ago it was part # ARBRD66... 4:10 and down Dana 70 with 35 spline axles it also said out of stock just so you know
good luck steve
2k dually CTD excab, fullload, level kit 2"block, afe cai magnaflow 5" straight pipe, edge juice w att, airdog 2, DTT full billet, hytec 727d pan, 3:73'S, 4X4, 255/70/22.5's, smoked cab lights, halo's, debadged, mag hytec rear cover and a 7"dvd
Fade2black is offline   Reply With Quote
Old 07-28-2009, 08:02 PM   #14 (permalink)
powerbrake's Avatar
make sure you pull a shaft and make a good count of splines. my d70 has 32splines. an air leaker should give you good service. I went with a detroit soft locker and have no regrets. there is no clicking, banging or unexpected releasing. I WOULD NEVER PUT A LOCK RITE IN ONE OF THESES TRUCKS. It will break.
92 4x4, fuel screw turned in all the way, starwheel dropped to the bottom, 40 hp injectors, machined pin, detroit locker lets me smoke 'em evenly. auto meter pyro.
God Bless Our Country and Damn The Goverment
powerbrake is offline   Reply With Quote
