Old 05-01-2009, 10:47 AM   #1 (permalink)
ZSkibo's Avatar
Injector Tip size reference chart(found on an internet site site)
Found this surfing, thought it was pretty cool.
Via Chuck @ NewEradiesel.com 740-819-0457
stock 1st gen inj - 6x.009" = .000380" total cross sectional area
2nd gen 215 tips - 4x010 = .000314(17% smaller than stock)
non ic inj - 4x12 = .000452 (19% larger than ic inj)
185's = smaller than stock
190's = smaller than stock
230's = ?
300's = ?
ddp stg III = 50 LPM (liter per minute) 5 hole extrude hone inj
330's - 5x11 = .000474 (20% larger than stock)
2nd gen 370's - 5x12 = .000565 (48% larger than stock)
ddp stg IV = 55 LPM (only 10% larger than stg III's) 5 holes <.013
pods - 4x14 = .000615 (62% larger than stock)
2nd gen 435's - 5x014 = .000769 (twice as large as stock)
custom injectors -
6x13 = .000795
5x15 = .000882
6x14 = .000923
5x16 = .001005
6x15 = .001059
5x17 = .001134 (300% larger than stock)
6x16 = .001206
5x18 = .001272
6x17 = .001360
5x19 = .001416
6x18 = .001526 (400% larger than stock)
5x20 = .001570 (josh ayers custom p-pump inj)
6x20 = .001884 (500% larger than stock)
5x22 = .001900
5x24 = .002261
6x22 = .002280 (600% larger than stock)
92' W250, rhino liner bed+cab. Pump bombed: timing 18*, AFC out, #366 spring, POD's, #60 exh springs, 2ndGen piston pump (@18psi), BHAF, HX35/40 (60/60/12), 4" turbo back 6" stack, full gauges, Banks engine brake, onboard air, train horns!
ZSkibo is online now   Reply With Quote
Old 05-01-2009, 07:49 PM   #2 (permalink)
Admin
Paccool's Avatar
There is some good info there! New Era used to be a sponsor on this site and I also have a set of the 435's installed in my truck right now.
Stan
93 D250, PDR Twins HX35&HT3B, 60+# boost,PDR stage 2 head w/o-rings, PDR Cam, modified VE Pump, piston style lift pump, modified 5" intake w/AFE, ATS ported manifold,DTT 89% converter, 4" RIP exhaust, modified tranny, EGT/boost/tranny/tach gauges, TPS removed, a little chrome under the hood. Mag-Hitec tranny and diff. covers. Rear sway bar. Line-x bed liner, after market seats. Front end rebuilt with new springs - 2 " taller now. Single stage Water/Meth system installed. Oversized intercooler w/3" IC lines.
05 Chevy 2500 HD, Duramax W/Allison, 17" Hummer wheels w/285-70-17 BFG's, modified air box, ported turbo mouthpiece. Predator programmer.
Paccool is offline   Reply With Quote
Old 05-03-2009, 12:57 AM   #3 (permalink)
peobryant's Avatar
Yep, thats over on 1stgen.org.
Very useful information.
'91.5 D350, 2wd Dually, 4" Straight Pipe, 366 Spring, DennyT Stage II Fuel Pin, Isspro Boost, Pyro, Tranny and Fuel Pressure Gauges
Brothers: '97 2500, 12 Valve, 4wd, 5spd, 716rwhp, 1200+rwtq, Single turbo, Fuel only
peobryant is offline   Reply With Quote
Old 05-03-2009, 01:23 AM   #4 (permalink)
2nd gen 215 are 5x .0105, marine 300s are 4x.012
07 5.9 4x4 G56
mdavlee is offline   Reply With Quote
Old 06-09-2009, 11:42 PM   #5 (permalink)
RSWORDS's Avatar
Yeah New Era is over on Diesel Bombers now. Them and Coaltrain Diesel, I'm running soem coaltrain 6x016's and couldn;t be happier!
RSWORDS is offline   Reply With Quote
Old 06-16-2009, 11:48 AM   #6 (permalink)
wwm
wwm's Avatar
what would 100% over stock injectors be, and what kind of horsepower add do yall think that is?
06 Dodge Auto QCSB 4x4 short bed, 3.73, Superchip w/ Edge, silencer ring removed, K and N intake, Intake Manifold, 2" leveling kit, and rhino bed liner
1993 Dodge Cummins Project truck :pump mods, 100% over injectors, looking at twins
wwm is offline   Reply With Quote
Old 09-02-2009, 05:53 PM   #7 (permalink)
Alberta Southern VP
blacksmokecummins's Avatar
maybe we should start stating how much added actual RWHP these injectors are so if anyones got # put them up
Wats the fastest tdi out there cause im gunna be faster than it ive had enough bad luck with trucks for a while Sienna Diesel Power
blacksmokecummins is offline   Reply With Quote
Old 09-02-2009, 08:21 PM   #8 (permalink)
jimbo486's Avatar
i haven't had good experience with coaltrain or new era. i finally quit waiting around on them to return my phone calls and 4 messages left and never hearing a word back from them. i won't be recommending them to anyone in the future. no offense to anyone who has had good luck with them. if you've had good luck and experience with either of them, then right on! i'm having my stock 4x.012's built to 4x.014's which will be better than POD's cuz they'll have the proper spray angle AND they'll flow about the same as 370's (5x.012's).
- '90 D350 LE Cab & Chassis -
custom 9' bed - nv5600 - d70 3.54 posi - banks (?) intercooler - 4" turbo back - 4x.014's - piston LP - autometer tach - vdo boost - ultralite II pyro - 500K+ miles
jimbo486 is offline   Reply With Quote
Old 09-02-2009, 08:25 PM   #9 (permalink)
ZSkibo's Avatar
As far as guessing on RWHP it's a crap shot. Injector tip size/pattern doesn't directly correlate to HP, it's just increased fuel. If you have the air to burn it, you've got HP. If not, you've got smoke. Buying injectors by HP is somewhat pointless. Look for increased flow over stock, tailor your air to meet your goals.
Old 09-02-2009, 08:30 PM   #10 (permalink)
jimbo486's Avatar
that's exactly what i was looking for. i'm not impressed by what HP increase some companies "claim" you'll make. it depends on your application and your setup. the 4x.014's (not POD's) i'm getting will flow more than my stock injectors. it may not be much more than stock, but still an increase.
Old 10-09-2009, 12:08 PM   #11 (permalink)
YOUNG GUNS15's Avatar
didnt rust bucket in diesel power have the 300% bigger injectors?
94' cummins 12 valve. lots of fuel and a crazy ___ year old
SPECIAL THANKS TO TOXIC DIESEL
YOUNG GUNS15 is offline   Reply With Quote
Old 10-09-2009, 11:59 PM   #12 (permalink)
jimbo486's Avatar
jqmile (owner of project rust bucket) is running 6x.016's. makes them a little more than 300% larger than stock.
