Old 08-30-2008, 12:22 AM   #13 (permalink)
gear jammer 91"'s Avatar
I have heard that same of the bully dog pin's had issue's with being too soft. They would get a groove in them. This has probably bean fixed but b cautious. Also try lookin up dennyT, he's over on DTR and he makes a great pin.
91 now intercooled W250, 1/4 from runaway, AFC lever MIA, 366 spring, BHAF, piston lp, PDR HX-40, 4"straight piped, W/M, egt, boost gauge, timed to the head, 270K+ and a getrag, KDP tabbed 402HP 865TQ on meth
gear jammer 91" is offline   Reply With Quote
Old 08-30-2008, 03:22 PM   #14 (permalink)
cummins man
92 smokin blacky's Avatar
yeah i installed my bully dog fuel pin but i put the washer back in with it...and then i heard that if you shaved part of the washer off it would help, but i just decided to take it right out, so i then took it out, and it helped a lot!!! more bottom end, because the pin would go farther down and fuel more, and more top end also because the pin could move farther down and the needle could go just about all the way up the pin, cuz with the washer, you could see it wouldn't travel all the way up the pin... and yes just the pin alone does seem to help quite a bit, more bottom end and top end, they claim that it gives you up to 40 hp. I got mine on ebay for $100!!! Mine hasn't seemed to be soft, but i haven't had it too long, just make sure you put some lube on the pin before you put it back in (i used the white engine assembly grease) just don't put too much or else it will all go to the bottom and be in the groove of the pin where the needle hits the pin.
Black 92' Cummins, Intercooled, auto, Bully Dog fuel pin with washer removed, Full Power screw: around 2 turns, smoke screw:3 1/4 turns, AFC Starwheel:almost 1/2 turn, stock turbo and injectors for now, straight piped, ASA Modified cold air intake with AFE filter, Isspro boost and pyro gauges, Trail Mark M/S Radial tires, 229K and rollin...
92 smokin blacky is offline   Reply With Quote
Old 08-30-2008, 03:26 PM   #15 (permalink)
cummins man
I'm not sure how the bully dog pin compares to a ground stock one... but i really like my bully dog one, and for $100 bucks, i get more power, and i can always put my stock pin back in just in case the tranny starts slippin or somethin like that, so to me its worth the money for the power and for the reason i can go back to my stock one just in case.
Old 08-30-2008, 03:34 PM   #16 (permalink)
proffesional bs'r
plowboy1138's Avatar
i just ground mine down to about nithin, buried the star wheel adjuster and left the washer out, for nuthin lol, i noticed a lil more power on take off and alot more smoke lol
andrew stein, 92 D350 47rhauto banks flexplate, gorend tc, transgo kit drw pyro&boost gauge 40+boshe injectors fuel pin ground and turned with the smoke screw turned all the way in full power screw, holset hx40 WHEN I GROW UP I WANNA B JUST LIKE BEER PLAY
plowboy1138 is offline   Reply With Quote
Old 08-31-2008, 04:41 PM   #17 (permalink)
chuckect's Avatar
OMG I just had a test drive with my new bully pin and I can not believe it is the same truck. I guess though it might have some to do with my new ($900) injection pump.
92 RAM 250, 234.000 - rebuilt 3.54 rear-end, rebuilt auto trans. 40 HP injectors, K&N, just added a bully dog fuel pin (8/28/08)
chuckect is offline   Reply With Quote
Old 09-01-2008, 12:02 AM   #18 (permalink)
There was a Bully Dog pin in the 92 in my sig and it had at least a 1/16th groove in it when I sold it. Very soft for being 1-1/2 years old.
91.5 W250 rusty p.o.s., pods, no afc, pull cable, AM electric FP gauge, Isspro boost, pyro, 366, 91 W350 parts truck, (SOLD) 92 W250,
OHIO Coal Rollers
921stgen is offline   Reply With Quote
Old 09-01-2008, 10:56 AM   #19 (permalink)
cummins man
yeah i really like my bully dog fuel pin, I'll remember to keep checkin on it though and make sure it doesn't wear a groove... hopefully it will last me, it should.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
