Radio Schematic - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 01-24-2014, 08:46 AM Thread Starter
Tlane3546's Avatar
Radio Schematic
Does anyone have a schematic of the inside on the radio? or has some knowledge of the wires coming of the tape deck?
1993 Dodge D250 CC Cummins 12V converted to W250, fuel pin turned all the way, power screw turned 2 turns, star wheel turned 2 turns, 1/8th inch timing bump, HE351CW upgrade
Tlane3546 is offline
post #2 of 10 (permalink) Old 01-24-2014, 10:05 AM
When I did mine I went to Car Alarm, Car Stereo, Mobile Video, and Cruise Control Info for Installers and it is free.
2005 Ram 2500 6SPD 2WD
jcruznby is offline
post #3 of 10 (permalink) Old 01-24-2014, 05:13 PM Thread Starter
Tlane3546's Avatar
I looked, I didnt find anything. Basically I'm looking for the right and left signal wires coming out of the tape deck. I'm going to splice into these with a Auxiliary input so I can plug my phone into my stock radio.
Yes there are easier ways to do this like buying FM direct and modulators, but I'd rather not. And I know this is possible just have to find the wires.
post #4 of 10 (permalink) Old 01-24-2014, 05:50 PM
country_hick's Avatar
In the 98.5-02 section these were recently posted. Maybe one of the threads can help.
Aux input Oem Radio DIY
How to add aux input to the RBR radio
1997 3500 club cab 3.54 gears towing & camper pkg. Still stock with a built transmission at 120k. 4" exhaust, 4kgsk, and exhaust brake waiting for installation. 37337 upgrade. Still need ideas for improvements for hauling 15k fifth wheel.
country_hick is offline
post #5 of 10 (permalink) Old 01-25-2014, 12:06 PM Thread Starter
Tlane3546's Avatar
I looked at both of those and they differ from my stock 93 tape deck greatly.
I have my radio apart and I'm trying to find the right and left channel using a multimeter, Im having bad luck tho.
Could anyone provide any insight?
post #6 of 10 (permalink) Old 01-26-2014, 12:25 PM
Have you tried to look at an aftermarket wiring harness? Wires should be the same, color wise.
smokesalot91 is offline
post #7 of 10 (permalink) Old 01-26-2014, 01:06 PM Thread Starter
Tlane3546's Avatar
I need a schematic of the inside of the printed circuit board. I'm trying to find the pre-amp inputs
post #8 of 10 (permalink) Old 01-26-2014, 02:54 PM
packing_mules's Avatar
Do you have a Chilton's manual? If not I can check if it's in there.
packing_mules is offline
post #9 of 10 (permalink) Old 01-27-2014, 03:53 PM Thread Starter
Tlane3546's Avatar
No, I do not. However I got it all done. I ended up going to the junk yard and getting a Tape deck out of a 91 Dodge Daytona. It has the cd slave plug in the back. So i just tapped into that.
The on/off switch basically grounds the AUX ON pin out and thats what tells the head unit to switch to pick up the CD input. Ill do a write up on this soon.
The whole purpose was to have a factory radio with AUX input, I dont much care for aftermarket head units
post #10 of 10 (permalink) Old 10-12-2014, 04:45 PM
avvblanc01's Avatar
a write up on this would be awesome since I feel the same way. Aftermarket head units just don't look right in these old trucks
Instagram: @AVVBLANC 2006 2500 qcsb 4x4: auto, yukon hubs, Fass, 2mic Cat/baldwin 5mic FWS, 17" Method NVs & 35's, Edge insight, custom retroshop, heads/tails, Carli pintop, Amp steps 1993 D350 5spd, HID projectors, 4in TBE
avvblanc01 is offline
