Cummins Ramcharger - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 01-30-2013, 09:04 PM Thread Starter
Cummins Ramcharger
I have an old ramcharger that I would like to fix up. Me and my sister both came home from the hospital in it so it has sentimental value. I h e came up with two options, both involve a 12v. I could fix it up as is and put axles out of a w250 into it. I could also cut the front off and weld it onto the back of a crew cab body and put it on a 250 or 350, crew cab, short box frame. Making it a 4 door ramcharger. The roof is rotten around the rain rail, and the floor is gone in the front. And opinions to help me decide? Or any suggestions as to what I should do with it?
Thanks,
Alex
alexrieger94 is offline
post #2 of 9 (permalink) Old 01-30-2013, 10:14 PM
disgoup's Avatar
I'd shorten a w250 frame and put the body on it. Seems to be the way to go.
91 W250, Automatic slushbox, HE351CW, 2nd Gen intercooler, 3" Intercooler piping, 4" Exhaust, Fuel screw 1 turn from runaway, stock fuel pin turned, Crew-cab build in part gathering stage. 78 4wd crew SB donor.
disgoup is offline
post #3 of 9 (permalink) Old 01-30-2013, 11:52 PM
Cummins TurbaDeezel
Wombat Ranger's Avatar
That crew cab idea sounds pretty terrible to be honest. RCCUMINS89 has a badass RC on a W-250 frame/drivetrain, it's a nice setup.
The Hungry Diesel
'04 2500 4x4 NV5600 QCLB
Wombat Ranger is offline
post #4 of 9 (permalink) Old 01-31-2013, 12:24 AM
STONR's Avatar
My father in law slapped the 8-lug axles under his RC. Seems like a lot less work than placing the body on a shortened truck frame.
The 4 door thing would be badass because you just don't see any Excursion/Suburban sized Dodges. A lot of work though on a rig that sounds like it already needs a lot of work. Do what YOU want!!!
2005 2500 QCLB, BigHorn, 48RE/3.73, Edge Juice w/ CTS + Turbo Timer, TransGo Shift Kit, GDP 20/2 fuel filter on the frame, ISSPro EV2 Oil and LP Pressure in the cubby hole, Custom Diesel Steering Box Brace
STONR is offline
post #5 of 9 (permalink) Old 01-31-2013, 01:38 AM
jawman's Avatar
there is a guy that has had one for sale for a while and he shortened a w250 frame. I would think it would be easier to swap everything over from a cummins truck then shorten the frame. I guess it depends on how much you have to shorten it and where.
jawman is offline
post #6 of 9 (permalink) Old 01-31-2013, 02:55 AM
u2slow's Avatar
I'm going to work with the frame I have. I want to drive this thing next month, not next year. It's 2wd, so its only a matter of swapping the engine and 8-lugging it. Will go 4wd later... have some 07 Superduty axles kicking around.
If building a frame, the one to start with is a cummins supercab, or a cab & chassis. They have the tall 8" channel
93 W250 Club 6BTA |5spd |60/80/3.54/Lockright |3" lift |315/75R16 |HX35 |5x.012s |BD pin & gov spring
90 D250 6BT/5spd/3.54.........84 Ramcharger (work in progress) 6BT|5spd/D70/3.07
u2slow is offline
post #7 of 9 (permalink) Old 11-28-2013, 12:38 AM
chris first gen's Avatar
i think the hard part would be the roof panel. then again its only MEDAL.
chris first gen is offline
post #8 of 9 (permalink) Old 11-28-2013, 12:46 AM
revemup15's Avatar
4dr ramcharger ftw!
95 farm truck
revemup15 is offline
post #9 of 9 (permalink) Old 11-28-2013, 02:32 AM
nornev1stgen's Avatar
Originally Posted by revemup15 View Post
4dr ramcharger ftw!
What he said I've pictured this before kinda like a suburban/excursion kinda deal
91 ic 4x4, de straight pipe, home made cai, dennyt stage 2, nv4500, South bend Clutch, 04 ram seats, pump mods, SkyJacker 2.5 in lift, INDUSTRIAL PHATSHAFT 62/68/14, ps intercooler, coolertubz, DAP 7X.0105 SAC injectors
nornev1stgen is offline
