93 d350 to a 85 w250? which way to go? - Dodge Cummins Diesel Forum
post #1 of 14 (permalink) Old 11-20-2012, 09:49 AM Thread Starter
Bikeneck's Avatar
I have a 93 d350 and just picked up a 85 w250 gasser. What way would be easiest to get a 4x4 out of them? I have custom paint on the dually but will restore the 85 body if necessary. Would swaping axles from the 85 to the 93 be the best way? The 85 has a 727 tranny and the 93 has the 46rh tranny.
1993 dodge d350 stock with all the free tweaks, K&N Air Filter, automatic, rear airbags, custom paint. Still working on her.
Bikeneck is offline
post #2 of 14 (permalink) Old 11-20-2012, 09:53 AM
CumminsBoy94's Avatar
Usually people say to use the frame that's in the best shape and roll with that one.
1991 Dodge Ram W250 4x4 I/C Cummins Turbo Diesel, A518, HX35, 230k miles, pump turned up, Borgeson steering shaft, 2.5" Skyjacker Lift, Denny T Stage 1, Diamond Eye 4"
CumminsBoy94 is offline
post #3 of 14 (permalink) Old 11-20-2012, 09:57 AM Thread Starter
Bikeneck's Avatar
The 85 is a reg cab and the 93 is a ext cab. Im not afraid of custom fabrication. Any ideas?
Bikeneck is offline
post #4 of 14 (permalink) Old 11-20-2012, 09:58 AM
I'm not sure if the axles are going to match up right? I'm gonna let someone more experienced handle this one. I like 4x4 reg cab duallys the most, but I'm assuming you want a single rear wheel truck?
The Following User Says Thank You to CumminsBoy94 For This Useful Post:
Bikeneck (11-20-2012)
post #5 of 14 (permalink) Old 11-20-2012, 10:13 AM Thread Starter
Bikeneck's Avatar
It does not matter to me. I think single rear would be better for my taste but on the other hand I do pull alot. I am afraid I would miss the dually in the long run. Just looking for input. I like the ext cab because of the dogs and camping trips. Thought about the 93 ext cab on the 85 frame and shorten the bed. ?? Or stretch the frame??
Bikeneck is offline
post #6 of 14 (permalink) Old 11-20-2012, 10:16 AM
Why not just keep it as a Extended cab dually on that frame and throw the 4x4 parts under there?
post #7 of 14 (permalink) Old 11-20-2012, 10:20 AM Thread Starter
Bikeneck's Avatar
I could do that. What about the tranny and transfer case. Will the 727 bolt to the cummins and hold up? The 85 w250 is a gasser.
Bikeneck is offline
post #8 of 14 (permalink) Old 11-20-2012, 11:05 AM
I think you should leave each truck the way they are. the w250 likely has a d44 front and d60 rear and they will not live long under a cummins. you need a d60 front under the dually.
comotionman is offline
post #9 of 14 (permalink) Old 11-20-2012, 11:12 AM Thread Starter
Bikeneck's Avatar
Bikeneck is offline
post #10 of 14 (permalink) Old 11-20-2012, 01:09 PM
You dont want to go from a 46rh to a 727. The 727 has 3 gears and no lockup or nothin.
post #11 of 14 (permalink) Old 11-21-2012, 06:01 PM
19cummins92's Avatar
The 203 tranfercase wont take it. Neither will the dana 44.
'92 W350 cc/sb project, '89 W250, '91 W250, '90 D350,'92 D250... Its all junk!
19cummins92 is offline
post #12 of 14 (permalink) Old 11-22-2012, 08:28 AM
The 85 probably has the 6" frame vs the 7" under your dually, guss which is stronger? The 85 probably has an NP208 tcase, might have a 205 if it's a heavy 3/4 The heavy 3/4 might also has a 7" frame.
I'd convert the dually, use the 85 axles and upgrade as things grenade. Depending on use the 44 might last a long time. Keep the dually rear.
92 d250 le creampuff, rc auto and stone stock.
Ruderunner is offline
