Oil pressure - Dodge Cummins Diesel Forum
Old 02-05-2012, 04:48 PM   #1 (permalink)
Fischer's Avatar
Exclamation Oil pressure
When I start my truck in the morning the oil light comes on and stays on untill i rev the motor up.
Is this somthing I need to worry about?
Fischer is offline   Reply With Quote
Old 02-05-2012, 05:45 PM   #2 (permalink)
9297oldram's Avatar
The factory gauges are not very reliable get a aftermarket oil pressure gauge and see what the pressure is. If you still want your stock one hooked up you can put a "T" there so you can have both.
92 D250 custom made bed, 190 inj., 16cm , electric cooling fan, 2nd gen air horn, 5spd.
97 2500 4X4 DDP 40 HP, no 8 fuel plate, homemade 3" intake horn, BD converter
9297oldram is offline   Reply With Quote
The Following User Says Thank You to 9297oldram For This Useful Post:
Fischer (02-05-2012)
Old 02-05-2012, 06:01 PM   #3 (permalink)
Fischer's Avatar
is the oil pump slow to build pressure typicly?
Old 02-05-2012, 06:02 PM   #4 (permalink)
Fischer's Avatar
and how do you get your truck info under your replys?
Old 02-05-2012, 06:32 PM   #5 (permalink)
That's the "signature" in your profile.
j_martin is offline   Reply With Quote
Old 02-05-2012, 06:35 PM   #6 (permalink)
The oil pressure should come up within a second or two at idle. I'm guessing something's wrong with the oil pump pickup tube, loose or something so it drains back and fills up with air.
Not good. The engine can be pretty dry at start up anyway. Shouldn't have to wait for a drink of oil, and especially shouldn't have to be revved for oil.
Old 02-05-2012, 06:59 PM   #7 (permalink)
Fischer's Avatar
is the pickup tube attached to the pump? mabey a dumb question but i don't know.
Old 02-05-2012, 07:02 PM   #8 (permalink)
9297oldram's Avatar
Yes it's attached to the pump and has a pickup that sits in the lower part of the pan. I would get a gauge as soon as possible and check pressure before ripping pan off.
Old 02-05-2012, 07:20 PM   #9 (permalink)
anoldbiker's Avatar
My son had this issue and we changed the oil pressure sending unit.
Cheap fix.
2006 Dodge Ram 2500, Big Horn, QuadCab, LB, 5.9L, 4x4, 48RE, 3.73, 5" s/s exhaust, Banks Ram Air / Super Scoop, Smarty S06, Transfer Flow 56 gal tank, XX-Fuel System, 285/70/17 MT
anoldbiker is offline   Reply With Quote
Old 02-05-2012, 07:26 PM   #10 (permalink)
9297oldram's Avatar
The reason I put a gauge on was because I could never figure out how many PSI. a line was. What I was guessing to be about 40 PSI was really 75 PSI cold.
Old 02-05-2012, 07:26 PM   #11 (permalink)
Cheap fix.
The point is........
I'd at least temporarily connect a 100 lb pressure gauge and verify that the engine is getting oil pressure quickly after start up.
If it is, replace the switch.
If it isn't and all you do is replace the switch, you'll have wasted the cost of the switch AND you delay the repair needed to keep the engine from catastrophic failure. (Read that much $$$$)
It could be the switch. I have seen them fail.
How much do you know about what this engine is supposed to sound like? If it doesn't rap before the light goes out, maybe it's worth while to just throw in a switch and see if it was defective.
If you're unsure and/or inexperienced, don't gamble, diagnose it.
The Following User Says Thank You to j_martin For This Useful Post:
Old 02-11-2012, 06:05 PM   #12 (permalink)
Jossi's Avatar
I gave a tee there at the oil hole, I have a gauge to look at under the hood, the the custom one in the cab....don't run that motor with low oil pressure! Check it asap!
"----If it ain't loud, lowered, long, and flatblack....an ain't belchin' black smoke...an don't have at least 1 Turbo....it ain't about S***!"-SCREAMIN' METAL
Jossi is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2012, vBulletin Solutions, Inc.
