Hole in Fuel Tank- - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 01-29-2012, 09:27 PM Thread Starter
RacinDuallie's Avatar
Hole in Fuel Tank-
What is the stuff to use that diesel fuel won't break down? Hole is in top of tank.
RacinDuallie is offline
post #2 of 11 (permalink) Old 01-29-2012, 09:57 PM
Moderator
9297oldram's Avatar
I've used black RTV.
97 2500 4X4 auto, 8 fuel plate, BD converter
96 F250 SC zf5, 4x4, SAS, 92 Cummins, Bosch 190's, THD fuel pin, THD HVLP with adjustable fuel pressure mod, WM, wh1c hybrid 60/64/.82a/r
9297oldram is online now
post #3 of 11 (permalink) Old 01-30-2012, 01:04 AM
peddlebike's Avatar
Did 24 or 30 gallons leak out?....Ooops, hole in the top!
'02 Regular cab 4x4 .... 5sp, 3.54 lim. slip, Juice/Attitude, 4" turbo back.
peddlebike is offline
post #4 of 11 (permalink) Old 01-30-2012, 07:39 AM Thread Starter
I was thinking of a more durable repair?
post #5 of 11 (permalink) Old 01-30-2012, 07:52 AM
Mr. Vehicle Destroyer
Shibbyutman's Avatar
iTrader Score: 7 reviews
Its a plastic tank... you could get a plastic weld kit and melt 'er back together if you want a more "permanent" repair.
Otherwise I'd head to your local auto parts store and get a stick of the two part fuel tank epoxy. I've used it on multiple beater cars to success every time (provided a large piece of the tank doesn't fall in when applying it.
ITW Performance Polymers/1 oz. Magnum Instant Gas Tank Repair (16709) | Fuel Tank and Radiator Epoxy | AutoZone.com
Says metal tanks only, but I've used it on both.
Back in the common snail game. 03 SO 2wd 480,000 miles and counting.
Parts for sale: Van Aken SmartBox, 03-05 Banks 6Gun, TST PMCR w/R37 remote also have another full one w/R49. RACEME 07-09 Delete Tuners
Shibbyutman is offline
post #6 of 11 (permalink) Old 01-30-2012, 12:25 PM Thread Starter
What is this plastic weld kit you speak of?
post #7 of 11 (permalink) Old 01-30-2012, 12:35 PM
They are basically a soldering Iron of sorts, with some filler rod.
Stand by for link.
post #8 of 11 (permalink) Old 01-30-2012, 12:40 PM
Plastic Welding - Harbor Freight Tools
could be yours for the bargain basement price of 16.99
extra filler rod for 4.99
post #9 of 11 (permalink) Old 01-30-2012, 05:02 PM
and make sure your tank vents are working, the only time I've ever seen a plastic tank fail is when the cap fails to vent and it actually cracks the tank.
post #10 of 11 (permalink) Old 01-30-2012, 07:36 PM
Put some permatex on the screw that made the hole and put it back in.
j_martin is offline
post #11 of 11 (permalink) Old 01-30-2012, 07:38 PM Thread Starter
It was from a mount plate for a dump body that kinda wobbled on the forklift and well...........
