Taquache's Resto Mod - Dodge Cummins Diesel Forum
Old 12-02-2011, 09:59 AM   #1 (permalink)
Diesel Junkie
Taquache's Avatar
iTrader Score: 6 reviews
Well I have decided I want a 1st gen and I'm going to look at one tomorrow (Saturday)
I need the opinions of those very knowledgable with these trucks so that I can make an informed decision.
Here is what I know:
1990 5 spd 4x4 with a 6" lift. RCLB
Problems:
Steering stabilizer bracket is broken off
Needs front end work (I'm assuming tie rods ball joints all that)
Does not start well with the key but will push start
needs carpet
used to have an air dog on it
Pump and timing are turned up and leaks a little
leaks a little oil
Shifter is broken (guy uses a pipe to shift it)
He is asking $2500 I plan to start at $1800
None of these sound very serious to me but I'd like some input preferably with some estimates on prices to fix the problems.
I will need to get this truck to Daily Driver status quickly and then will go through and fix it up towards what I have planned
Here is the craigslist ad for the truck:
first gen cummins 4x4 6 inch lift 5 speed
Thanks in advance for the help
Click HERE To Find Out How To Help Bring <-- THIS 8 sec Diesel Drag Truck from THAILAND to the NHRDA World Finals in Ennis, TX September 28th
Taquache is offline   Reply With Quote
Old 12-02-2011, 10:08 AM   #2 (permalink)
1STGENFARMBOY's Avatar
With everything you listed that needs attention, that price is a steel for a 4x4 5spd that will go down the road with a little work.
even if theres some hidden problems it's still worth the money.
thats my oppinion.
Dar
93 W250, A518, 3.54, 80hp sticks, 16cm housing, 60mm Gillett, all pump mods, P/S intercooler, Tim W cooler tubes, walbro 392, 366 spring, denny t pin, homemade BHFF, BHAF, 1/8in bump, 4in DP to 5in , gauges,
1STGENFARMBOY is offline   Reply With Quote
The Following User Says Thank You to 1STGENFARMBOY For This Useful Post:
Taquache (12-02-2011)
Old 12-02-2011, 10:13 AM   #3 (permalink)
Diesel Junkie
Taquache's Avatar
My thoughts exactly. Unless the body is completely rusted through I should be picking it up
Old 12-02-2011, 01:01 PM   #4 (permalink)
Diesel Junkie
Taquache's Avatar
lunch time bump for more opinions
Old 12-02-2011, 01:13 PM   #5 (permalink)
Moderator
9297oldram's Avatar
How many miles on it? Good thing about the 5 spd the ECM can be totally eliminated if you have problems with it and want to go manual controls.
92 D250 custom made bed, 190 inj., 16cm , electric cooling fan, 2nd gen air horn, 5spd., Dana 61 3.31 gears, 1 stage W/M set up
97 2500 4X4 auto DDP 40 HP injectors, no 8 fuel plate, homemade 3" intake horn, BD converter, BHAF, electric cooling fan
9297oldram is online now   Reply With Quote
Old 12-02-2011, 02:22 PM   #6 (permalink)
Diesel Junkie
Taquache's Avatar
Not sure on miles. He said 87000 but it doesn't work. It was his DD then he wanted to turn it into a mud truck hence pulled carpet.
Sounds like it has has a rough life
Old 12-02-2011, 02:23 PM   #7 (permalink)
Diesel Junkie
Taquache's Avatar
Tell me more about the ECM bypass
Old 12-02-2011, 02:27 PM   #8 (permalink)
Moderator
9297oldram's Avatar
I think a 90 has a external regulator and maybe a cable driven speedo which would be good. The grid heaters you can wire to operate by push button and use when needed. Can't think of anything else that would be controlled by the ECM. My speedometer doesn't work so I use a Garmin.
The Following User Says Thank You to 9297oldram For This Useful Post:
Old 12-02-2011, 02:29 PM   #9 (permalink)
Diesel Junkie
Taquache's Avatar
Sweet! This may work out
Old 12-02-2011, 02:36 PM   #10 (permalink)
Moderator
9297oldram's Avatar
It sounds pretty rough for 86,000 miles, I'll bet closer to 186,000. $1,500-1,800 sounds like a good price. Also there is a 1 wire option for the alternator which a couple members has used and like.
Old 12-02-2011, 02:51 PM   #11 (permalink)
Murf & lil Murf's Avatar
Id probably start around $1400 and go from there. Get a feel for the guys personality and use judgement. But from what your describing the truck has quite a few problems but nothing real serious. A few hundred dollars and some time and youll have a $3500 truck imho. Id probably say that the truck has quite a bit more than 86k on it. Truck in the sw usually are pretty solid, if taken care of, til 250k-350k. Good luck and dont be too jjmpy on it. Ive seen it on CL before.
1981 GMC K35 3+3, Dually, '91 Cummins Stock 620K, 518, NP205, 3.73's 6" Lift, 295's
1993 W350 Dually Cummins, NV4500, NP205, 4.10's, 4" DE, 2" lift, 255's KM2, 058
Murf & lil Murf is offline   Reply With Quote
The Following User Says Thank You to Murf & lil Murf For This Useful Post:
Old 12-02-2011, 03:29 PM   #12 (permalink)
Diesel Junkie
Taquache's Avatar
yea i'm figuring on it having atleast 100k more miles.
You have seen this one before? Thats good news for me.
I'm guessing your $3500 estimate is about correct
