dana 60 spindle nut torque specs? - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 11-09-2011, 10:31 PM Thread Starter
mcnally351's Avatar
Hello I'm replacing the front brakes and packing the bearings, not sure what the torque spec on the spindle nuts are. The truck is a 91 w250 with the dana 60. found nothing under search. thanks -Mcnally351
91 Dodge Power Ram cummins 12v stock 4wd auto- de 4"- cai - firestone helper bags. (Sold
99 2500 ecsb 24v 4x4 424k stock
mcnally351 is offline
post #2 of 9 (permalink) Old 11-09-2011, 11:33 PM
The wheel bearing nut? You just snug it up to your liking. I think, technically, they say it should take so many pounds of force to make the rotor spin....but as far as I know, there's not an exact torque spec for the adjuster nut.
'86 Chevy K30 ('92 6BT, NV4500, NP205) Denny T Stage 1, SPS 62/71/14, 3200 gsk, pump turned up, 7x.011 sac, piston lift pump, full throttle mod, 181/210 cam, 3" intercooler pipes
Croatan_Kid is offline
post #3 of 9 (permalink) Old 11-09-2011, 11:42 PM
Page 8 of this manual.
In a nutshell, Torque inner nut to 50 ft lbs., then back off 1/4 turn maximum. Install outer nut and torque to 50 ft. lbs. Total end play .001" - .010"
j_martin is offline
post #4 of 9 (permalink) Old 11-10-2011, 01:09 AM
trkklr77's Avatar
you had better tighten the outer nut tighter than 50lbs!!!! that will back off.
i just put my big hand rachet on it till she stops, for arguments sake i will say 100+
arbeit macht frei
trkklr77 is offline
post #5 of 9 (permalink) Old 11-10-2011, 01:35 AM
90powerram's Avatar
Try 200ft/lbs on that outer nut, otherwise it will back off. Use the aforementioned method for the first nut - torque to 50 then back off 90, install lock washer and torque outer nut. Bend tabs over.
2002 Ram 2500 24V 6-spd, 4" exhaust & AFE intake
90powerram is offline
post #6 of 9 (permalink) Old 11-10-2011, 08:42 AM Thread Starter
mcnally351's Avatar
Yeah that is what my gutwas telling me on the inner. I know you don't want to over tighten it. As for the outer 200 ft lbs seems like a lot but if it is acting as a jam nut that makes sense. Thank you all for the response
post #7 of 9 (permalink) Old 11-10-2011, 07:54 PM
i would not go 200 on the outer the lock washer with the tabs stops the outer nut from backing off even if you only tighten it 1 foot lb
i would say 50 to 100 max
1993 w250 , extended cab, getrag , skyjacker lift, 35s, crossover steering , borgeson steering shaft, dual steering stabilizer , traction bars , front spool and rear locker, air bags , 175hp injectors, pump mods ,3200 rpm spring , guages, THD high volume low pressure lift pump 95,000 original miles
123buster is offline
post #8 of 9 (permalink) Old 11-10-2011, 08:41 PM
The book says 50, but what do they know.
One thing I've heard is that some torque the inner nut to 100 or so before backing it off and setting zero lash. They say sometimes 50 won't fully seat the races.
200 ft. lbs. will shell out the threads on a well worn half high jam nut. Not needed, just needs to be tight enough to keep cornering forces from affecting free play. The keeper prevents it from unwinding.
j_martin is offline
post #9 of 9 (permalink) Old 11-11-2011, 09:42 AM Thread Starter
mcnally351's Avatar
Cool I'm going to do 50 inner and 80- 100 outer. I think that's plenty. Thanks for your help
