1st gen Crew Cab plans - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 09-11-2011, 10:11 PM Thread Starter
akamphi's Avatar
Been wanting to build one of these for years. Starting to do some more research on this again today and found this forum. Been reading through posts all afternoon and think I have a general plan. First let me say thanks for all the hard work and info out there.
I have been looking for a 92/93 Extended cab W250 with a cummings for awhile now that would be the base for a crew cab build. At this stage I'm looking for opinions on what would be the easiest build process.
Could a 92 or so ext cab long bed be used with an 85 crew cab and short bed? Or would the wheel openings in the bed be off? I'm guessing lengthening the frame is the only real way to go. Leave the option of using an 8' bed that way too.
From what I read an 85 crew cab body will bolt up with most everything except the firewall is different. What all would need to be done to a crew cab tub to make it bolt in usable assuming the frame work is done?
I'm hopping to end up with a 92/93 crew cab cummings in as close to OME looks as I can get.
akamphi is offline
post #2 of 8 (permalink) Old 09-11-2011, 11:38 PM
cummin's crewcab builder
iTrader Score: 11 reviews
There simple to do firewall is the same unless you go 5 sp then you have to add clutch slave cyl other then that wiring and pretty much everything bolt's back into the crewcab .I am in the process of doing my sencond truck Plus I have a spare crewcab shortbed 4x4 and also a Longbed crewcab frame if your interested just send me a PM when your done it's hard to tell it's not factory built .
Newest toy 2017 VW Golf Altrack TSI Sold 2013 Durango bit the dust 9-04-14
RIP Speedy the 67 vw died a very hot Death 5-17-2010 New toy 1985 crewcab longbed 4x4 conversion with a 93 cummin's and built 47rh with compushift mini controlled auto sxe62/70 turbo 6x13 injector's full 4 in Diamond Eye Exhaust ,366 spring and THD fuel pin .along with Boost and Pyro gauges and Tach .
simplysmn is offline
post #3 of 8 (permalink) Old 09-12-2011, 12:05 AM
draginmopars's Avatar
since our 74 crew cab floors were bad
we cut out the rust and used a 93 club cab fire wall
cummins/ 5 speed
http://ramchargercentral.com/diesel-...ummins-hauler/
draginmopars is offline
The Following 2 Users Say Thank You to draginmopars For This Useful Post:
akamphi (09-12-2011), thechoochlyman (09-12-2011)
post #4 of 8 (permalink) Old 09-14-2011, 03:16 PM
19cummins92's Avatar
best thing to do is find a crew cab truck and put the cummins in it.
'92 W350 cc/sb project, '89 W250, '91 W250, '90 D350,'92 D250... Its all junk!
19cummins92 is offline
post #5 of 8 (permalink) Old 09-14-2011, 03:42 PM Thread Starter
akamphi's Avatar
Thats what I'm thinking. I'm betting there are morth then a few out there with cummings already too. Saw a 2 wheel 85 crew with a cummings for sale yesterday. What would it take to convert to 4X?
akamphi is offline
post #6 of 8 (permalink) Old 09-14-2011, 08:12 PM
olde_blue's Avatar
Check out this thread for 4x4 conversion: 84 Dodge Crew Cab 2wd to 91 Cummins 4wd.
Both the crew cab short bed and club cab long bed have 149" wheelbases, but you can't swap stock cabs directly because the crew frame has a longer lowered section under the cab. If you did something like draginmopar's post (married the cabs), you might be able to put a crew cab on the club cab frame (with cab mounts moved), but rear seat would not have the leg and/or head room of a stock crewcab. You would also need to cut 4" off the back of the frame (longbeds have 42.25" rear overhang, while the shortbeds and Ramcharger have 38.25" overhang).
olde_blue is offline
post #7 of 8 (permalink) Old 09-14-2011, 08:29 PM
Piece of Cake to convert em just takes time
post #8 of 8 (permalink) Old 09-14-2011, 08:31 PM
Ram3500Dually's Avatar
There is no G in a Cummins....
2013 Ram 3500 Dually CTD 6.7/Aisin/4:10 LSD
Previous Rams:
90 CC Dually, 94 RC LB, 95 CC SB, 98 QC Dually, 00 QC Dually, 01 QC Off Road, 03 QC Dually, 05 QC Dually, 08 QC Dually, 10 CC Dually
Ram3500Dually is offline
The Following User Says Thank You to Ram3500Dually For This Useful Post:
randomb0b123 (09-14-2011)
