2nd/3rd gen wheels on a 1st gen? - Page 3 - Dodge Cummins Diesel Forum
Old 04-17-2008, 01:26 PM   #25 (permalink)
ChaseTruck754's Avatar
No - but let me explain...
All chevy and dodge 8 lug are the same as the pre 1998 ford 8 lug. They are a 8x6.5" bolt center (8x165.5mm)
The 98 and newer fords (technically Ford didn't make an 8 lug truck in 98 so it's really 99 - but that's a side note) are 8x170mm. These wheels can be drilled and steel sleeved to fit though...
2 other things you need to account for besides the lug pattern are the backspacing/offset - which is much higher on newer (2002 and newer typically) trucks. This higher offset will cause the tires to rub on many older tucks when the wheels are turned at full lock.
The last thing you need to worry about is the center bore on the wheel. Some of these center bores (hole in the middle that the hub sticks through) are too small. These can be fixed on a mill though if you want to go through the $/effort.
Now after rambling on all that - I think the 17" hummer wheels will be fine. I've seen them on k5 blzers before and they seemed to work well. These wheels and tires are cheap and easy to find now that all the knuckleheads are putting 20" rims and rubber band tires on those POS'
My cummins swap - 1974 Ford Crew cab http://www.cumminsforum.com/forum/cu...-crew-cab.html
ChaseTruck754 is offline   Reply With Quote
Old 04-17-2008, 04:24 PM   #26 (permalink)
unixcowboy's Avatar
Originally Posted by Captain Dean View Post
Will all the 8-lug wheels interchange? Ford / GM / Dodge / etc.
I have a chance to get some 17" Hummer wheels and tires cheap for my 91 Dodge.
Cap'n,
Don't know where the thread is offhand - maybe someone could chime in - but I saw a posting on what it take to mod the Hummer wheels to fit.
Bit of an effort if I remember, BUT -
They LOOK REAL GOOD lol3:
Check this out - these are 2nd/3rd Gen articles...
Another Way to Adapt H2 Wheels - TDR Roundtable
Hummer H2 Wheel Upgrade
'93 D250 Auto CC HX-40 60/65/17 w/hx50 flange - hit 57 held 55 psi OOPS => 6x16's <=, PS IC, CoolerTubz, 366 spring w/2 turn clipped, power screw bottomed-backed off 1 1/2 turn, M2 power pin, smoke screw fully out, custom AFC spring, modified top to get pin higher, '94 built trans - clutches and some hard parts, trans cooler under bed in front of rear wheel, 4510 w/4 1/2" intake and heat shield, htr grids MIA, 4" dp -> 5" pipe -> 5" Stack, 285's rear 265's front
unixcowboy is offline   Reply With Quote
Old 04-17-2008, 05:56 PM   #27 (permalink)
DOODAH's Avatar
the hummer wheels need to be machined 1/8th of an inch to except the dodge hub... the chevy trucks and hummers have hubsentric wheels...
SHAWN:NEW TRUCK 2003 3500 crewcab shorty 4x4 35s
98 12-valve 5-speed quadcab, shortbox 4x4 sport, with the 99+ sport bumper and grill, 97, 4x4 x-tended cab,Goerend brothers trans.
DOODAH is offline   Reply With Quote
Old 04-18-2008, 02:22 AM   #28 (permalink)
Thanks everyone !! I'm just amazed at the amount of information out here.
I contacted the seller and will have them shipped from Oahu to the Big Island.
This looks like an excellent small project. I will be doing the router method of enlargening the center holes.
Tires for my truck would be $1000 to $1400 and rims would be another [Oh my God]. These tires and rims are coming to me for $750 plus shipping, probably another $100 by barge.
Aloha from Kona, Hawaii. Captain Dean Towle
1991.5 Dodge Ram W250 CTD w/IC 4x4 5-speed Hummer wheels & tires
Captain Dean is offline   Reply With Quote
Old 04-18-2008, 03:02 AM   #29 (permalink)
Are you talkin H1 wheels, or wheels off one of those H2 POS'?
I like the wheels off the H2's but that's about it.
If it's H1 wheels you're getting then VERY good score. If they are for the H2, then you might want to look over here a bit. I see the 17" H2 wheels with the stock tires all the time for $300-500 or so. If you can score them from over here it might be cheaper even with shiping from the mainland. Living near LA has it's benefits for stuff like this. People are always taking stock rims and tires off of stuff and putting 37" rims (exagerating obviously) on. It seems every other car/truck I drive by had 20"+ wheels on it, and with so manystock take-offs flooding te maket the prices stay pretty low!
Old 04-18-2008, 01:24 PM   #30 (permalink)
These are the H2 wheels, identical to the ones in UnixCowboy's links in his post.
Shipping things from the mainland is more costly than shipping between islands. The overseas shipping companies have to accumulate enough stuff to fill a 40' container. It also has to go through a Freight Forwarder. The other option is UPS / FedEx which are both Ouch-worthy.
The inter-island shipper will accept a box or stack of tires and put it directly on the barge. No freight forwarders, no UPS / FedEx. One barge comes to the westside of the island each week. Another one goes the eastside each week.
Life is a little different in the middle of the Pacific.
Check out the volcano...
HVO Kilauea Status Page
Live Panorama of Halema`uma`u, Kilauea Volcano, Hawai`i
Recent Earthquakes in Hawai`i - Index Map
Old 04-18-2008, 01:26 PM   #31 (permalink)
Ah - I knew it was expensive over there (family lives on Kauai), but I didn't know how bad they screw you on shipping from over here. Then again the stuff we send back and forth is usually small/light enough to go UPS without needing to get out the vasoline
Old 04-18-2008, 01:30 PM   #32 (permalink)
We apply vasoline with a caulking gun.
Old 04-19-2008, 10:49 AM   #33 (permalink)
unixcowboy's Avatar
Granted the cost of most everything is higher there -
But compared to the weather, and how it it changes here in the 48, I think you've got the better end of the deal.
Especially for those retired that can afford the higher prices.
But I'm enjoying driving around the states and seeing the wonders we have here.
BTW - can't wait to see those wheels on your truck.
Old 04-20-2008, 09:57 PM   #34 (permalink)
Well, we probably do have the upper hand, living in paradise. I'm not a wealthy retired guy, just a working stiff. The weather is ALWAYS good in Kona but now we've got the Vog (Volcano Fog) from Kilauea. The air quality is not much different than LA.
My truck has a long way to go but I'm making progress. A transmission is on the way from Kansas, the tires & wheels are enroute from Oahu, and I still have to paint the 'ol guy.
Six weeks from now I hope to have it back in shape.
Old 04-21-2008, 11:35 PM   #35 (permalink)
tader's Avatar
Originally Posted by jsnolan99 View Post
Anybody have pics of aftermarket or 2nd/3rd gen wheels on a first gen truck. I have a 2wd that I would like to put some different wheels on.....
How about an awesome video?!?! 1st gen w/ 2nd gen 16" 5 spoke wheels. This truck is a beauty!! I'd trade my 02 for it!
YouTube - 1st gen cummins blowing smoke on the dyno
2002 2500 SLTPlus QC SB 4X4 Goerends 47RE, FBD 5" Strait Pipe Exhaust w/ Diverter Pipe and a 7" Mitered Grand Rock, 150 Sticks, BHAF, Edge Juice w/ Attitude, FASS 150, Leveling kit, 4:10s, TOYO 315's
tader is offline   Reply With Quote
Old 04-30-2008, 02:00 AM   #36 (permalink)
The new Hummer H2 tires & wheels arrived today. I'll carve out the middles this weekend and post a picture soon afterward.
I was surprised at how light weight they are.
Powered by vBulletin® Copyright ©2000 - 2012, vBulletin Solutions, Inc.
