Ve pump removal - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 02-12-2011, 09:02 PM Thread Starter
BC_03's Avatar
Ve pump removal
I'm trying to reseal leaking pump. My question is how much force is needed to seperate the gear from the shaft? I'm using a steering wheel puller and I can't get the bolts in perfectly straight due to the puller slots not coming in far enough I ended up bending the bolts on the puller and still the gears not separated. Any ideas?
03 555, Suncoast full billet TD, rack a gauges-rail,FP,egt,boost,tranny. 3" lift. Raptor 150. At some twins. 60 hp injectors. ride right bags.90 model 12v dually blows alot of smoke.
BC_03 is offline
post #2 of 8 (permalink) Old 02-13-2011, 02:15 PM Thread Starter
BC_03's Avatar
Nonone has ever removed a pump before?
BC_03 is offline
post #3 of 8 (permalink) Old 02-13-2011, 06:16 PM
huntinguy's Avatar
You need to get the bolts strait. I did it's with a homemade steering wheel puller.
89 w-250 4" lift, 4" exaust, tuned pump, electric lift pump, timing to the head, 2nd gen cooler, 500hp clutch, HE351VGT and a still under the hood.
other trucks- 89 w-250, 92 w-250
huntinguy is offline
post #4 of 8 (permalink) Old 02-14-2011, 11:16 AM Thread Starter
BC_03's Avatar
Was a alot of force required to separate the 2 I just don't want to break anything.
BC_03 is offline
post #5 of 8 (permalink) Old 02-14-2011, 07:55 PM
huntinguy's Avatar
Quite a bit of force. I thought I was going to twist of the bolts on my puller. Get some force on it then tap it with a hammer.
post #6 of 8 (permalink) Old 02-14-2011, 08:22 PM Thread Starter
BC_03's Avatar
Thanks man I got it off. I got the bolts a little tighter on the puller and used my long handle 12mm it popped right off. Appreciate your help.
BC_03 is offline
post #7 of 8 (permalink) Old 02-14-2011, 08:24 PM
Begle1's Avatar
There are holes in the gear that so-happen to be threaded. Those threads so-happen to be the same as bolts that are elsewhere on the engine; I think that the bolts that hold the pump on have those threads, if not then I think that the bolts that hold the air horn onto the heater grids do.
Once you have all the lines disconnected from the pump, have disconnected the three bolts that hold the pump to the timing cover and unbolt the pump support bracket from the back of the pump, thread bolts into the two threaded holes on the gear. They will thread through the gear and hit the timing cover; unless it's stuck on more than usual, the gear will pop off easily as you continue to tighten the bolts.
CumminsForum? I remember CumminsForum...
Begle1 is offline
post #8 of 8 (permalink) Old 02-14-2011, 08:32 PM
Pantelones's Avatar
iTrader Score: 4 reviews
Are you saying that you can remove the gear without a puller? By just threading the bolts through the gear against the back of the timing housing?
91 w250, non-intercooled, 727 Auto, fresh IP and LP and Stage 1 pin, 16cm exhaust housing, Boost, Pyro, and Trans gauges. 4" Lift, Jungle's / Skyjacker up front, Skyjacker rear, M95 Shocks. 20x11 Big Rigs, 305/55/20 Terra Grapplers.
Pantelones is offline
