centering dually wheels.. - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 09-25-2010, 03:39 AM Thread Starter
lets get serious here.. took me 7 hours today to try and align my rear wheels to be true... couldnt get them to line up perfectly and it was either one or the other out of whack... yes im using the conical lugnuts to try and get them centered..
is there any company that makes a centering ring for this crap??? i have one wheel thats slightly bent and the rest are perfect... im almost contimplating buying new wheels....
its almost bad enough that the axle looks bent... but its not... when i put one wheel and center it, its perfect... 2 wheels and its fooookked..
91.5 D350 Flatbed Dually, HE351CW, Built 46RH, 4.10 Gears, Denny T Pin, Timing Spacer, 3200 Spring, BHAF, 4" Exhaust, Glowshift 3n1, Borgeson Extreme Steering Shaft, 6K HID, K3LA Train Horn, 12000 Pound Winch.
Brucetafer is offline
post #2 of 9 (permalink) Old 09-25-2010, 01:23 PM
Are you putting the conical lugs in the concave holes, and one across from the other? If so, then you probably have a bent rim.
'97 3500 4x4 CC DRW, 4.10's, Banks PowerPack, BD tc, vb, eb, 60# springs, Torqloc, gauges...
'92 CC W350 DRW sold
'92 CC D350 DRW sold '12 Laramie CC 3500 4x4 SRW sold
brownbear is online now
post #3 of 9 (permalink) Old 09-25-2010, 06:41 PM
You also have to get your alignment pins on the hub lined up with the alignment holes in the wheels.
Buy a new steelie wheel to replace the bent one and enjoy.
DP
HIS- 93 W250 xcab LE 495k, Auto to Getrag conversion, 3.07. Hungry diesel 5x11s.
HERS 04 2500 QCSB, HO, Bully Dog, Air Dog, built auto unknown aftermarket sticks
dpuckett is offline
post #4 of 9 (permalink) Old 10-27-2010, 04:32 AM Thread Starter
ok, well they are out of whack again... the truck is an hour away, and i want to order hubcentric wheel rings to keep my rear dually wheels center to get rid of the stupid 60+ mph wobble... does anybody know the size of the hub on the dana 70 rear and wheel size too?? even better could i use electrical tape and go around enough to center the wheels that way??? anybody think of any other way to center then other than the conical lugs???
anyhow, im drunk, pissed off, and cant sleep... trucks driving me nuts... its eating up the new tires and gonna start really costing some cash if i dont get this taken care of soon... thanks
post #5 of 9 (permalink) Old 10-27-2010, 08:14 AM
ClassA4x4's Avatar
I have a 77 Dodge Class A motorhome that had the 8x6.5 17.5" dually wheels with the alternate concave/convex conical holes, and comes with the Dana 70 rear axle too. I replaced them with 19.5" GM dually wheels after I enlarged the hub holes and drilled the guide pinholes. The specs call for 325 ft-lbs for the 5/8 lugnuts and so I gave it as much as I could! So far they haven't loosened a bit! So check your lugnut torque.
77 Dodge Xplorer 307 Frank Ind 26-ft 4x4 Class A Motorhome 1st Gen '93 Cummins swapped in, 47RH/NP241, stock turbo, PS intercooler, ground fuel pin, starwheel, fuel screw turned, 366 spring, BHAF, M&H DTA, 4" downpipe, DNA muffler, ARB Lockers, 17500# winch.
ClassA4x4 is offline
post #6 of 9 (permalink) Old 10-27-2010, 12:03 PM
denman's Avatar
The 325 lb-ft spec is for the the stock fixed-washer nuts on the Dodge. The conical lug nuts call for about half that. You got a Cummins in that MH? I saw one last summer that the guy transplanted in his MH, .... he was a high miler and really enjoyed the better fuel economy, ...
1993 D350 DRW, Getrag G350, 767,000 km, IP 3/16" adv, CB, Sirius Sat radio, flat deck with headache rack, Intelligent Battery Saver which isolates the battery if draining to below 12V or so.
denman is offline
post #7 of 9 (permalink) Old 10-27-2010, 01:45 PM
ClassA4x4's Avatar
Not yet, I have a 440/727 there now. I recently bought 2 Rams (93 and 95) Cummins trucks and I plan to swap the 93's engine and the 95' trans/T-case and axle into the motorhome. It will be a 4x4 motorhome with a Cummins from a 93 (1st Gen Intercooled). the engine from the 95 is shot from overheating.
post #8 of 9 (permalink) Old 10-27-2010, 07:24 PM
I have a slide in on my dually so I can tow my wheeling rig. 15.3 mpg in a house with a 7000# trailer on the back. Gotta like that.
It does have a bad vibration about 65. I suppose I should check my rears. I haven't had them off since I've owned the truck.
GumbyIL is offline
post #9 of 9 (permalink) Old 10-27-2010, 09:44 PM
denman's Avatar
Hey ClassA4x4 that's exciting, .... I hope you'll keep your camera handy while you shoe horn that power train into your MH. Just getting the clutch hookup will make it unique among MHs, and you'll be able to win bets from other campers who won't believe it's 4WD!
denman is offline
