Wild gauges!
I was driving my truck last weekend, first time its went more then 10 miles all winter, and my speedo starts going bazerk. Would not stop sweeping up and down. Luckily I had the GPS in the truck so I could use that for my speed, but why does it do this? I am assuming it has something to do with the flickering lights and spastic gauges (all the others bounce around as well including my Tach and Pyro). Truck charges fine, never has a low battery and when I did check it, it was charging decent. Is this a ground issue or is there something else going on? Oh and it gets worse when I turn the lights on.
Thanks,
Joe
92 W350, NV4500, pump turned up a little, fuel pin turned. Aluminum flatbed, 5th wheel. Have guages, but need to be installed, SOON! Have 16cm to put on at the same time.
