CumminsForum.com is the premier Dodge Cummins forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 03-11-2010, 10:38 AM   #1 (permalink)
Front brakes?
hey-Hey!!!,
Is there any upsizing the front calipers/pads over the stock ones? I'd like a bit more front brake and would rather just get a bigger OEM part( that might include rotors). It is a 2WD '90 model.
cheers,
Douglas
1990 D250, NV5600, 16cm housing, PAC brake, TST Kit KDP tab, Powr-Lok'd 3.07....IC soon
1991 D250, 16cm housing
Douglas2 is offline   Reply With Quote
Old 03-11-2010, 01:09 PM   #2 (permalink)
I bleed Diesel
Orangeracer's Avatar
i think that the stock one is the only one.
selling a brand new rebuilt nv5600 4x4 out of a 2000. $4000 obo. Trade for first gen.
Orangeracer is offline   Reply With Quote
Old 03-11-2010, 01:31 PM   #3 (permalink)
One of the parts stores websites lists different sizes for the caliper piston, but that's all I know of.
You're the first in a long time, if ever, to want MORE front brake bias. Usually, it's the rears that quit.
One thing I did notice was that when I put in new pads on my W250, the pedal firmed up quite a bit. Pads were thin and worn crooked as a circuit judge (ok, maybe not THAT crooked), and I'm thinking with the caliper piston moved farther in he caliper body, there is less volume to pressurize, thus making the brakes work with less pedal travel.
DP
93 W250 xcab LE 300K. Built auto, HX35/40-16 turbo, ISSPRO fuel pressure and pyro. Other goodies and updates coming......
dpuckett is offline   Reply With Quote
Old 03-11-2010, 06:21 PM   #4 (permalink)
DP
The rears are easy, put the dually wheel cylinders in( they're bigger than the 250's ). The fronts OTOH, are another story it seems...
cheers,
Douglas
Old 03-11-2010, 11:05 PM   #5 (permalink)
PPDMostWanted's Avatar
What about a valve reducing the rear brakes? Proportioning valve. I bought one but I don't know if I'll use it.$120
Old enough to know better, Too young to resist. 1990 w250 CTD LE reg cab. Straight piped 3.5''. A-727 tranny. 249,000 miles. All STOCK! Gauges - EGT, Boost, Tranny, Tach, and Fuel Pressure. Soon to experiment with, Waste Vegetable Oil.
PPDMostWanted is offline   Reply With Quote
Old 03-12-2010, 08:41 PM   #6 (permalink)
Same part number for the duallies and SRWs up front.
There was an article in the TDR a few years back about brakes and piston sizes and whatnot. Gist of it was, you can increase your piston bore size on the wheel end (like your 7/8 to 1-1/8 wheel cylinder upgrade), but you can go too far, and actually go backwards in braking ability if you increase things too much at the wheel without a corresponding increase in master cylinder bore size as well. Goes back to physics- bigger volume, all else equal, pressure will be lower. Lower pressure leads to less brake bite. Just food for thought, not trying to discourage you or anything. The brake system is a major weakness on 1stGens.
DP
Old 03-12-2010, 09:11 PM   #7 (permalink)
iowacummins's Avatar
yeah stock 3/4 ton truck had 7/8" wheels cylinders 1tons had 1" wheel cylinders. chevy 1 tons had 1 1/8" wheel cylinders. that is waht i installed on my truck. very nice upgrade along with 3" shoes from one tons.
for the front i wonder if there is any chevy application that used lager calipers? what teh one tons use?
1993 Dodge W250 Reg cab. Auto. Red Oak Diesel 5x.012s. .010" headgasket, A1 Technologies Head studs. Pump adjusted everyway i can for now. Timing bumped 1/4" and Aurora 3000 turbo. 4"-5" exhaust 7" Chrome CAT stack.
iowacummins is offline   Reply With Quote
Old 03-12-2010, 10:03 PM   #8 (permalink)
hey-Hey!!!,
The stock Dodge calipers are 3" pistons( done with a tape measure at Napa). Finding a 3-1/4" would be nice; heck even a 3-1/8" would probably be enough to get some of my money.
All this talk about brake upgrades and I sit here with 20 y-o stock rubber flexible hoses...heh-heh-heh. Guess some kevlar or braided stainless would be in order.
cheers,
Douglas
Powered by vBulletin® Version 3.8.5
