CumminsForum.com is the premier Dodge Cummins forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 03-10-2010, 06:26 PM   #1 (permalink)
good_ole_whiteboy's Avatar
how ya gettin high
i was just wonderin wat the best lift kit for the first gens is im thinkin 6 inches also i was wondering if there r lift kits made for first gens or do yall have to compromise thanks yall
good_ole_whiteboy is offline   Reply With Quote
Old 03-10-2010, 07:00 PM   #2 (permalink)
Check these guys out... they will make it as high as you want to go!!!
http://dnrcustoms.com/dodge7293suspension.html
92 Dodge D250
"If women don't find you handsome, they should at least find you handy."
dovehunter79 is offline   Reply With Quote
Old 03-10-2010, 07:03 PM   #3 (permalink)
DieselSharker's Avatar
I can't say how I get high here.
As far as my truck goes....6" Skyjacker. One of the PO's put it on and used blocks so here shortly they will get replaced with springs and maybe some bags to help out with the repo unit.
Seven-Point-Three said: I'm not stirring the pot, I giving you guys time to prepare yourselves for international owning cummins at sled pulls for life
SUPPORT YOUR VETERANS
DieselSharker is offline   Reply With Quote
Old 03-10-2010, 08:06 PM   #4 (permalink)
Brandonsmokincummins's Avatar
try Summit Racing
91 W250 5 speed Built trans lots of fuel lots of air south bend clutch denny T stage II 5 inch exhaust traction bars
OHIO COAL ROLLERS
Brandonsmokincummins is offline   Reply With Quote
Old 03-10-2010, 09:57 PM   #5 (permalink)
huntinguy's Avatar
69-93 @ NTW
87-93 Dodge 2500 and 3500 4 Wheel Drive - Top Gun Customz
Alcan Spring - Manufactures Fine Custom Leaf Springs
Custom Suspension - Custom Leaf Springs
89 W-250 Flatbed 5 speed, cummins reman(95) non-I/C, 4" turbo back, AFC tuning. Fuel pin ground. More to come.
Warming the globe since 1989
huntinguy is offline   Reply With Quote
Old 03-11-2010, 04:17 PM   #6 (permalink)
W150CTDproject's Avatar
huntinguy's done his homework, possibly a wish list too lol
92 W250 w/90 engine. work stock puller "All Spooled Up"
01 QCSB, 79k miles, AFE intake, 4" MBRP, auto,soon a HotRod VP, Fass 150
G'n'G Diesel
W150CTDproject is offline   Reply With Quote
Old 03-11-2010, 07:12 PM   #7 (permalink)
huntinguy's Avatar
Yep!
Old 03-12-2010, 08:21 PM   #8 (permalink)
jer1's Avatar
This is where I got my 6" kit. Some people have complained about the Skyjacker springs sacking out under the weight of the Cummins, but I haven't had any problems. Anything over 4" will require front driveline correction. I've got a high angle cv shaft and still have some pretty good(bad) vibration. Also, with 8" total lift & 38's, I get serious rubbing when crossed up or turning. Fine if on the road, but if 4xing cutout flares are needed.
Dodge Ram 1 Ton Pickup suspension lift kits by Skyjacker
91 W250, reg.cab 4x4, 5spd, 6" susp, 2" body lift, 36" Buckshots, Powersmoke IC, Banks high ram, Haisleys studs and fire rings, PDR valve springs, Bullydog boost and pyro(pre turbo)gauges, BHAF, 4" DP, dual 5" exhaust, HTB2 62/14, tweaked pump, 1/8 timing bump, 3200 rpm spring, POD's, 3.54 gears(in need of 4.10's)
If it aint broke, the pedal is on the right
I'm just smart enough to know when I've done something dumb, but stupid enough to do it again
jer1 is offline   Reply With Quote
Old 03-13-2010, 03:24 AM   #9 (permalink)
riesenbr549's Avatar
Hey jer1 have you tried lowering the transfer case? I use to do that on my chevy mudd trucks back in the day.. just make/find 4 1" spacers and put between frame and cross member might help a bit with vibrations ??
89 W250 stcab at,maxed out!!
95 3500 clubcab 5-sp #10 bhaf
98 3500 Quad 12v full billet at every banks opp
riesenbr549 is offline   Reply With Quote
Old 03-14-2010, 12:54 PM   #10 (permalink)
cumminsramcharger's Avatar
im going with alcan 6 inch front springs, 2 inch rear springs, a shackle flip in the rear, dual front and rear shocks, cross over steering with hydraulic assist, new front high angle drive shaft, and for "fender flares" im going to build either 4 or 6 inch flared bed sides and front fenders.
im hopping to have at least the fenders and bed sides done in the next month or two.
im also going to run load bags in the back, because the springs will be set up to flex and carry the weight of the truck and not much else. ill also make front and rear traction bars.
1989 w250 (getting p-pumped 12v and 5 speed)
1988 w350 ramcharger (getting stripped and then a tube chassis)
cumminsramcharger is offline   Reply With Quote
Powered by vBulletin® Version 3.8.5
