- - REGISTER - CALENDAR - INFO - SITE HELP - RULES - STAFF - MEMBERSHIP - ADVERTISE - CONTACT US - |
| 89-93 Non-Powertrain Discussion of 1st Gen. Topics Not related to the Powertrain...NO ADVERTISING |
Borgeson Shaft Install with pics.
I've been lurking and gleaning information from your archives for a while now and figured it was time I contributed something!
This is pretty basic but maybe not for everyone and lord knows, I love pics as reference. So, you need, Hammer 7/32's drift punch Small pry bar 5/32's allen wrench 3/8ths 12 point socket and ratchet rag, loctite, WD 40 (good enough for NASA, good enough for my shop!) Before you start, obviously park so your tires are straight and the steering wheel is centered. First thing I did was give all the bolts at the top of the shaft connection a blast of WD to start penetrating the bolts. While that was setting up I disconnected the vacuum line coming from the brake booster to make it easier to get my hands in there. I also marked the rag joint with a paint marker for reference, Next I went underneath and knocked out the set pin on the steering box coupler. A little WD helped here as well. ![]() After that, a light pry with the bar and she slipped right off. ![]() After that I headed back up top to start undoing the rag joint. I ducked into the cab and turned the steering wheel over to lock to add resistance. Had to unlock and re-turn it to access the bolts on the other side. I undid them on the LOWER side at the rag joint and then backed out one safety bolt to allow me to slip the top of the bottom shaft off the connection. ![]() Once loose, pulled out the old shaft and as you can see....totally punched! ![]() Now the fun part...new shaft going in. Started at the top in reverse order. Slid the rag joint connection past the safety pin and did up the rag connections. Blue loctite is your friend here. Don't forget to tighten down the safety bolt! ![]() Now, unlock your steering wheel and make sure she is centered. Extend the lower part of the steering shaft and fit it onto the steering box splined shaft. Take note of where groove from original lock pin was as our new set screw does not want to be in there. Mine lined up so I slid the shaft coupler further towards the steering box to clear the groove. Tighten in new set screw to mark splines for filing. ![]() Pull steering shaft u joint off and hit the box splines with the file to create a flat spot for the set screw to seat in. (blurry photo but to the left of original groove) ![]() Once filed, slide u joint back onto splined shaft and crank in the set screw. (loctite is your friend here as well) Once tight, add the lock not. Finally slide collar up to the bottom of the rubber boot, tighten set screw to keep it in place and you should wind up with something that looks like this: ![]() Man, that is sexy! Once done, did a quick double check of everything and the test drive. The difference is unreal. A highly recommended upgrade. After 100 KM (60 miles) re check everything to make sure nothing has loosened. Hopefully this helps!
93 Ram 250 LE. Gold on Burgundy. Borgeson shaft, air bags, camper tie downs, trailer brakes and an RPM gauge. |
| The Following 2 Users Say Thank You to Ram Fan For This Useful Post: | Haulin4aLivin (03-10-2010), Laz04 (03-10-2010) |
#2 (permalink) |
Nice write up! Thanks for the pics. This thread will be a guide when I do the swap on my 92.
O6, Mega Cab, 3500, G56, SRW, 2WD, PSM Intake, Amsoiled, Gutted Toruqe Tube, Pacbrake PRXB, Smarty SR. JDiehl |
#3 (permalink) |
![]() Join Date: May 2007
That looks pretty. Mine is pretty rusty by now but still works great and made it easy when I had to replace the input shaft seals on the steering box.
Seven-Point-Three said: I'm not stirring the pot, I giving you guys time to prepare yourselves for international owning cummins at sled pulls for life ![]() SUPPORT YOUR VETERANS
#4 (permalink) | |
thanks
91 W250 5 speed Built trans lots of fuel lots of air south bend clutch denny T stage II 5 inch exhaust traction bars ![]() OHIO COAL ROLLERS |
#5 (permalink) |
I bleed Diesel
![]() Join Date: Aug 2007
did you say anything about tighting down the clamp that keeps it from shorting?
selling a brand new rebuilt nv5600 4x4 out of a 2000. $4000 obo. Trade for first gen. |
#6 (permalink) |
the stering wheel is cocked to one side a bit i hate it will that fix my problem? Nice wright up I agree and the pics were most helpful
''1991 w250 LE 4x4 5 speed non Ic 3'' off the turbo 6'' tip'' pump turned up! Alot more "COAL ROLLING'' HX35 coming soon and single 7''stack
#7 (permalink) |
I call for a stickying!
89 W-250 Flatbed 5 speed, cummins reman(95) non-I/C, 4" turbo back, AFC tuning. Fuel pin ground. More to come. Warming the globe since 1989
#8 (permalink) |
i dont understand why you need to file a spot if there is one already there
1991 w250 non int,pump maxed,35" boggers,5spd swap,hx50,stock sticks,soon dual disc,gov spring, sticks |
#9 (permalink) |
there is just a hole in the splines, no grove. from the factory it had a pin go through everything, the new part just has a set screw which needs the groove to seat in.
1989 D350 2wd, 5 speed, flatbed, LED's, 4" straight pipe w/6" tip, smoke screw turned in one turn, everything else bone stock! Rotella T and Royal Purple! UA local 653 Plumbers, Pipefitters and Welders
#10 (permalink) |
Some-Sho Some-Go
![]() Join Date: Jul 2008
Nice write up for sure....
-Jerrod- 2002 3/4 ton X-cab Short Box 4x4 5 speed, Volant CAI, Blue Chip VP44, Edge J/A*HOT*, PDR HX40, AD 100, CFM+, BD short shift, Noise Makers, Flo-Pro SS Duals... http://www.hotroddieselclub.com its the myspace for diesels!
#11 (permalink) |
I don't like the idea of a little screw instead of a pin going straight through. Why would they do that?
'92 W350 4x4 LE Club Cab DRW auto, 138k, work in progress.. |
#12 (permalink) |
My Borgeson Shaft came in this weekend, I am about to do the install! Thanks for the write up and pictures, it will give me the upper hand in this one!
92 W250 220k miles, EX-Cab, 4X4, A518 with potentiometer mod, 6" Skyjacker lift, 35's, injectors, tweaked pump, 5" stacks
