external voltage regulator write up? - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 02-07-2010, 10:07 PM Thread Starter
CUMMINS7's Avatar
well think that junk pcm took a crap. ive searched all night and day trying to find a write up on how to by pass the one in the computer to one that mounts on the firewall. already bought the advanced auto special.
problems im having: first started about a month ago the battery kept gaining and losing voltage, have to hook it up to the battery charger every day. it seems after i start it, shut it off, and start again it will sometimes stay charged with out popstarting it everywhere i go.
then tonight i had it hooked up to the battery charger and started it up and left the charger hooked up so my grid heater could get all the power it needed (the light and relay tick for a good 15-20 mins at all times) well i turned my parking lights on and went inside till it warmed up. i came out and the lights were off so i checked the fuse it was blown. i put four fuses in it and it kept blowing so i jumped to 40 amp fuse and they would stay bright for like 2 secs and go dim but stay on i checked for burning wires and all that stuff but no sign. well after that i played with the light switch for a couple mins and now they seem to work fine.
im writing such a long write up so i could narrow it down and get it straightened out ounce for all. sorry
and this all started when it got cold out and when i took my intake horn and grid heater off too polish but i hooked it up the same way i took it off.
any help would be greatly appreciated. thanks and have a carefull night
00' 2500 4x4, 10" lift, 38s, 150hp sticks, ATS 3 pc, high ram, adrenaline, airdogg 150, BHAF, gauges, auto to nv5600, valair clutch
CUMMINS7 is offline
post #2 of 11 (permalink) Old 02-08-2010, 07:26 PM
Diesel_Addiction's Avatar
iTrader Score: 26 reviews
Converting to an old style voltage regulator ('92 and '93 only) from DTR
FAQ
Also i found this entire thread extremly usefull for anyone with a first gen.
http://www.dieseltruckresource.com/d...t-t102027.html
96. NV4500 Swap. 1 3/8" Input. Upgraded Hydros. Valair Street Dual. KDP Tabbed. ISSPRO. AirDog DF-200. Hellmann Sump. BHAF. 8" Miter. No Plate. 60lb. Springs. 4k GSK. .022" DVs. .120 Holders. Pump Tuned. 17* timing...
Diesel_Addiction is offline
The Following User Says Thank You to Diesel_Addiction For This Useful Post:
CUMMINS7 (02-09-2010)
post #3 of 11 (permalink) Old 02-09-2010, 04:49 PM Thread Starter
CUMMINS7's Avatar
well went out and got 4 of them headlight switches that was a big fail luckily they were free. and now the harness that plugs into the switch burnt up but just one wire was bad. i talked to a couple of my buddies around here and they say its common to go threw them all the time. and advanced wants 75 dollars for a plastic piece with 8 some odd wires. is there any way to rig some thing up so it dont do this everytime it snows?
as of now:
no parking lights
no gauge lights
smoke from the dash
if i turn my pking lights on my truck shuts off
no turn signals
no brake lights
no hazzard lights
battery goes dead in about 15 minutes
no radio
i am really close to go trading it for a V3 triton geo metro and setting this turd on fire and push it off a cliff.
CUMMINS7 is offline
post #4 of 11 (permalink) Old 02-10-2010, 01:15 PM
unixcowboy's Avatar
as of now:
no parking lights
no gauge lights
smoke from the dash
no turn signals
no brake lights
no hazzard lights
no radio
Just before you push it over that cliff - PM me - I want to be at the bottom to catch it
2011 Long Bed Crew 3500 w/6 Alcoas set up towing a 40' 5th wheel RV. Custom front bumper/grille guard and rear fender protection
unixcowboy is offline
post #5 of 11 (permalink) Old 02-10-2010, 09:15 PM Thread Starter
CUMMINS7's Avatar
it was just pushed over you might have enough time to save it found the biggest cliff i could find lol just kidding i got on e-bay and checked out a bada$$ machine. so i think i might keep it haha, but check out this truck on ebay its under ram 3500 89-93 its blue and white dually with 38s freshly rebuilt
CUMMINS7 is offline
post #6 of 11 (permalink) Old 02-11-2010, 10:11 PM Thread Starter
CUMMINS7's Avatar
followed all the directions on that tdr FAQ forum but still no charge does somebody have a more detailed write up please help im at advanced in the middle of the parking lot off my cell phone
CUMMINS7 is offline
post #7 of 11 (permalink) Old 02-12-2010, 11:01 AM
http://www.cumminsforum.com/forum/94...w-89-02-a.html
Heres a how to off this forum for a Ford VR and an older Dodge VR
92 Dodge D250
"If women don't find you handsome, they should at least find you handy."
dovehunter79 is offline
post #8 of 11 (permalink) Old 02-13-2010, 12:03 PM Thread Starter
CUMMINS7's Avatar
can i get some bumps on this my truck is still sitting at advanced i put a new optima battery $245 a new alternator $200 3 voltage regulators $45 new terminals $45 all new fuses and relays $50. i noticed i can get it to charge if i take them two wires off the post of the alternator and hook one to ground and the other to a 12 v source it will charge but it goes up to 16 or 17 volts and that aint good it goes up when i get on the throttle.
i hooked it up just the way it shows on all the fourums but it stays at a low 12 instead of a low 14 and thats not hooking it up to the regulator nothin happens or changes when i hook it to the regulator. PLEASE HELP!!!!! I HAVE NO WAY TO WORK AND MY TRUCKS AT ADVANCED AUTO PARTS. I HAVE 13 DOLLARS LEFT ON MY CARD I GOT TO MAKE IT LAST SO PLEASE HELP!!!!!!!!!!!!!!!
IVE CALLED AROUND AND ASKED ALL THE EMPLOYEES BUT THEY SAID THEY NEVER SEEN ANYTHING LIKE IT
CUMMINS7 is offline
post #9 of 11 (permalink) Old 02-13-2010, 12:48 PM Thread Starter
CUMMINS7's Avatar
Also the relay i got was made for my truck thats what i dont understand if its suppose to be internal. its for a 1992 Dodge W-250 with the 5.9L Diesel and they give me the same one every time. am i getting the wrong one by any chance nobody gives part #s and its a single battery. i cut all the wires for the alternator going to the pcm and ran all new. i have a good ground and still nothin. but now instead of keeping a charge at 12 volts it goes straight to nothing. BUMP
CUMMINS7 is offline
post #10 of 11 (permalink) Old 02-13-2010, 08:27 PM
I wish I could help but I am in the same boat... the only answer I have gotten out of anyone is to change the VR or grounds.... I have ohm'd wires out to the N'th degree and I am still overcharging at 16 Volts... I have found a post where someone fixed his back in July of last but I havent had a chance because of all the snow but I will be trying it tomorow... here is his fix and here is the link to that post, I hope it helps you out... http://www.cumminsforum.com/forum/ne...eply&p=1777988
Originally Posted by KnightOwl View Post
Figured out my problem. I decided to double check my IGNITION HOT wire. When i turn my ignition on, i am getting 12volts out of that wire like i should..... However, for some reason i decided to double check the Voltage Regulator since it was my 4th one and i was also running out of ideas. So connecting the hot from the POS battery made my voltage run steady at 14.50 ...
So the wire that i was using is obviously causes my voltage regulator to jump from 14.90 to 16 every 2 seconds. So that is not a good power source, why its doing that i don't know. (It stays steady when wire being tested) Anyways, the wire i was using (if you have a 12vavle engine) i was using it off a spare 2 PIN clip that's empty and located right by the valve cover plate. It was the green wire.
Now that i figured out that its the wires fault (maybe has too many wires running through it) which possibly causing the regulator under power and makes it act up. (when not connected correctly, my fuse would blow inside the cab listed under "10amp ENGINE" .
So since problem is fixed, i am stuck again however. Where can i find a place to connect my new HOT wire? Obviously running it from POS will drain the battery over time. Where is a good source to get my power from on IGNITION on a 12vavle cummins? 94-98
92 Dodge D250
post #11 of 11 (permalink) Old 02-14-2010, 08:02 PM
I tried this today and this fixed my overcharging issue... I was charging at 15.99 volts constantly, I took the power straight from the battery and it started charging at 14.77 volts consistently... I wired in a $6 relay and now everything is perfect!!!!! Hope this helps!!!
Jeff
92 Dodge D250
