Anyone disable the clutch safety switch? - Dodge Cummins Diesel Forum
post #1 of 21 (permalink) Old 02-02-2010, 11:38 PM Thread Starter
JBradley500's Avatar
I always start my truck and let it run a while before i drive it. Im sick of needed to bend over to push the clutch in to start it (or hop up in the truck). I know its not as smart as just leaving it hooked up but even if its in gear and let off of the clutch its going to take off.
Does anyone know what im supposed to do? My truck has cruise control too.
92 W250- K&N Filter, Smoke Screw Adjusted, Synthetic Transmission Fluid.
340hp/662tq (8/24/12)
JBradley500 is offline
post #2 of 21 (permalink) Old 02-03-2010, 12:51 AM
Josh9112's Avatar
then get an auto and have some one build it up for you so it can handle the power!!! or just put a push button start in it I put one in my wifes honda car ran 2 wires to the starter and back to the button and wala no clutch needed to start it and it turns on fine
1991 w250 LE 4x4 5 speed non Ic 3'' off the turbo 7" stack, Denny T performance AFC delete top
2012 RAM ST 4x4 6.7 H.O. S&B CAI FULLY DELETED and loving it
Josh9112 is offline
post #3 of 21 (permalink) Old 02-03-2010, 12:54 AM
grizzly_man07's Avatar
genuine SMARTA$$ right there boys
SOLD: 91 d250 ic 5sp
92 d250 auto ext. cab. 366 spring. afc MIA straight pipe w/ 5in tip
grizzly_man07 is offline
post #4 of 21 (permalink) Old 02-03-2010, 01:58 AM
90powerram's Avatar
If you look under the dash at the plastic contraption attached to the clutch pedal, you'll find 2 wires running from it to a plug. Cut (or splice into) the wires from the clutch-start cancel switch, and either twist them together or run the splice wires to a momentary switch - you can find factory ones in the older Toyota trucks, and they even say "clutch start cancel" on them.
2002 Ram 2500 24V 6-spd, 4" exhaust & AFE intake
90powerram is offline
post #5 of 21 (permalink) Old 02-03-2010, 02:04 AM Thread Starter
ok i figured it would just be a normally opened switch. i didnt know where to look or if there was something to do with the cruise control. do you know about that?
post #6 of 21 (permalink) Old 02-03-2010, 02:09 AM
90powerram's Avatar
I'm not sure about that as I don't have cruise, but you're right about the switch. The ECM probably has a pin to read when you press the pedal to shut the CC off, and hitting the added switch would most likely do the same thing.
post #7 of 21 (permalink) Old 02-03-2010, 09:54 AM
jcole11's Avatar
i got mine jumped mine started messing up i just mad a wire with two ends on it and hooked it in to each side
1990 dodge ram w-350 Denny t fuel top, aurora 3000, water meth
jcole11 is offline
post #8 of 21 (permalink) Old 02-03-2010, 06:15 PM
I bleed Diesel
Orangeracer's Avatar
My auto truck that i made a 5speed. i bypassed it. gf tends to want to start it when i leave her in truck but just makesure you never leave it in gear and your fine.
On the trans there is 2 wires when it is an open circet the engine wont crank. so you twist together and there you go.
1996 f250<f450 fummins
1997 f350 fummins
1992 fsuperduty cummins 5speed dump fummins
my projects never are good enough
Orangeracer is offline
post #9 of 21 (permalink) Old 02-03-2010, 06:22 PM
Brandonsmokincummins's Avatar
watch it when u do it will start in first gear happened to me left my lil brother in it and he started it when it was in first gear and it was goin through the yard when i came out to get in it
91 W250 5 speed Built trans lots of fuel lots of air south bend clutch denny T stage II 5 inch exhaust traction bars
OHIO COAL ROLLERS
Brandonsmokincummins is offline
post #10 of 21 (permalink) Old 02-03-2010, 06:57 PM
Richie O's Avatar
Its actually better for the engine to start without pushing the clutch. It does not put a load on the thrust bearing if you start it in the engaged position. Helps the bearing live longer. Some guys have had trouble with thrust in engines as low as 250,000. Bad thrust bearing = crank walking around.
89 dodge 3/4 4x4, A727 ,3.07 gears, factory L S , powerstroke intercooler, S300, stans exaust with stainless tailpipe, fuel power screw turned?, fuel pin turned to deepest, 3 turns smoke screw, 1/2 turn down on starwheel.
93 W250 ex cab, 6X16's, 60 GDS, rag
Richie O is offline
The Following User Says Thank You to Richie O For This Useful Post:
cstalnaker (04-14-2012)
post #11 of 21 (permalink) Old 02-03-2010, 07:18 PM
Old 'n Rusty's Avatar
I like the option of being able to turn it on or off. I like the option of being able to use the starter to move the truck a bit. A half dozen times over the past 40 years I have made my volvo's get out of the way, cleared an intersection or just in one case drove a block to a gas station on my starter. On the other hand I know what boneheads some people can be and don't want to risk the liability issue should someone else drive my truck. These babies don't stall real easy either.
91 (08-90) D250
5sp 2wd 511k VE 'adjusted', 3200 spring, Pyro, boost, 3.54 ,:thumbsup KN, 1\8" timing bump, 25mpg city 30mpg hiway 20mpg towing 6k 5'er
R60/7, Volvo 245 GL 320 k km's, f150 4x4 5 spd, MPG's are in Imp gal's
Old 'n Rusty is offline
post #12 of 21 (permalink) Old 02-04-2010, 01:33 AM
jimbo486's Avatar
that's a good bit of information! so in other words, starting with the clutch engaged is better?
- '90 D350 LE Cab & Chassis -
- 366 Spring - M3 Pin - KSB Spacer - 4x.014s - Piston LP - I/C'd - Fluidampr - HTT Super 40/35 w/ WG 14cm - 4" Exh. - NV5600 - Con OFE - Ultralite II 60psi Boost & Pyro -
jimbo486 is offline
