Gelling while driving... - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 01-31-2010, 10:39 PM Thread Starter
Well I had a first time experience the other day... For the first time in 10 years of owning various diesels (first CTD), my truck started to gel up while I was driving...
It was below 0 in the a.m. when I started it... It started fine and ran fine for the first 2-3 miles, then started to lose power... Once I got off work the temps had come above 15* and the truck ran fine.
So what are you guys doing to prevent gelling when driving?
"lightly modified" 85 Crew Cab: 92 CTD, 6" lift, South Bend ConO clutch, ISSPRO gauges, 5x.014s, HTT 62/65/13, ported, studded and o-ringed, 4" turbo back, piston lift pump, M2 fuel pin, M&H timing spacer, pump turned up, 3200 RPM governor...
freak007 is offline
post #2 of 6 (permalink) Old 02-01-2010, 02:46 AM
suicidejockey's Avatar
Location: somewhere between ND and TX, but land in UT when im home
Power service......works great, that or howes
2014 RAM 2500 mega 4x4 auto coil sprung x4 stock for now
suicidejockey is offline
post #3 of 6 (permalink) Old 02-03-2010, 01:57 PM
Winkles's Avatar
Yep on both. had a 2 week stretch of negative temps. Put that goop in and no problems.
RIP - 1993 W250; 60HP injectors, 366 Spring, Icebox Intake w/ S&B filter, 4" Str8 Pipe, AT w/ First-Stage Billet Converter, and 4.10 Gears. Isspro Gauges: Pyro, Tach, Boost, Tranny Temp. And of course, High-Beams on the floor!
Winkles is offline
post #4 of 6 (permalink) Old 02-03-2010, 06:27 PM
Old 'n Rusty's Avatar
My son drives three diesel vehicles in Minnesota. They mandate a small percentage of bio-diesel there. Even a gallon of anti-gel did not prevent his Kenworth from gelling. He tries to fill up in a non-bio-diesel state but an accident as he was leaving Iowa blocked access to an off ramp and forced him to carry on and do a fill at home. Ouch.
His payloader and his semi gelled. He pulled both with his 98 cummins and even it was on the edge of gelling. He was lucky a neighbour had a shop big enough to put both units in. I think Minnesota should ease up on the bio-diesel in cold weather or somebody ought to formulate an anti-gel which works with bio-diesel.
91 (08-90) D250
5sp 2wd 511k VE 'adjusted', 3200 spring, Pyro, boost, 3.54 ,:thumbsup KN, 1\8" timing bump, 25mpg city 30mpg hiway 20mpg towing 6k 5'er
R60/7, Volvo 245 GL 320 k km's, f150 4x4 5 spd, MPG's are in Imp gal's
Old 'n Rusty is offline
post #5 of 6 (permalink) Old 02-04-2010, 06:40 PM
diesel drinker's Avatar
QUOTE=freak007;2574950]Well I had a first time experience the other day... For the first time in 10 years of owning various diesels (first CTD), my truck started to gel up while I was driving...
So what are you guys doing to prevent gelling when driving?[/QUOTE]
put some diesel additive in it. we run it in all of our tractors and my dad's dmax *gags* cant change my dad's opinion
diesel drinker is offline
post #6 of 6 (permalink) Old 02-06-2010, 11:35 AM
Left out in the cold's Avatar
I run 50/50 1 and 2 with a mix of PS, MMO, and motor oil.
I also have fuel heaters.
Left out in the cold is offline
