Ok thanks alot guys.
So here it comes: I replaces the fusable link with a fuse and the windows and blower motor worked for about 5 mins. When I tested it. I rejoiced that it was fixed and detailed me truck the rest of the day. Now the truck is all cleaned up and I'm ready to go cruise around with cold ac and working windows but low and behold I jump in turn on the ac and no blower motor, check the windows for functions and nothing. What the hell do i do now??? New fuse is a 30 and appears to be fine. When I remove the fuse and put a jumper wire it does nothing either.
10 4. I unplugged and re plugged the connection at the blower motor earlier and poof everything worked then I cranked it up 5 min. later turned the ac on and once again no windows or blower. I checked voltage at the blower plug comming from the truck and its like 11.5? if its getting 11.5 shouldn't the blower motor at least be trying to work??maybe its a bad connection at the plug?
