First gen dual batteries? - Dodge Cummins Diesel Forum
post #1 of 30 (permalink) Old 12-02-2009, 11:09 AM Thread Starter
Beefstick's Avatar
Has anyone put a second battery in their first gen to help with cold starting? I wired in a second one a couple of years ago, but they seem to be giving me more trouble than its worth. Batteries getting hot, grounding problems, lights dimming and brightening with the alternator. Has anyone else had these problems, or does anyone have any ideas.
Beefstick is offline
post #2 of 30 (permalink) Old 12-02-2009, 11:44 AM
GeneralC's Avatar
the lights dimming is probably the grid heaters cycling while its cold. i have a buddy at nashville auto diesel college and they just studied electricity. the instructor told him you can hook up a battery in a parallel circuit and double the cranking amps but stay at 12v. if you hook them up in series it doubles volts and keeps same cranking amps. parallel is positive to positive and series is positive to negative. i was thanking about trying it myself. whta kind of problems were you having ?
Sold: 1991 W250 5 Speed metallic blue. 3200 gov spring, pump maxed, M&H M3 fuel pin, timing bump, dipricol gauges, 4 inch Diamond eye, s300 and 6X16s and airdog 150.18" moto metal 955's, dual-disk, coolertubz.
GeneralC is offline
post #3 of 30 (permalink) Old 12-02-2009, 02:10 PM
wjones's Avatar
sounds like a voltage regulator issue...
fill out your signature so we know what truck you have... User CP > edit signature
, nv4500, club cab
wjones is offline
post #4 of 30 (permalink) Old 12-02-2009, 02:13 PM
gotacummins's Avatar
I would just rather use a Quality oversize single
[/B] 04F250 FX4 CC/12V/ZF6
SDX 5X14, HE351CW, 4" DP and custom exhaust ,cooler tubz, Denny T pin, 3200k spring
gotacummins is offline
post #5 of 30 (permalink) Old 12-02-2009, 05:15 PM
denman's Avatar
Mine had a single battery as stock, but I've got a heavy truck battery with steel posts (takes lead post adaptors) and something like 1300 CCA. Never any doubt about starting anyhow with this engine, but never know when a REAL cold start may be necessary. ...
1993 D350 DRW, Getrag G350, 767,000 km, IP 3/16" adv, CB, Sirius Sat radio, flat deck with headache rack, Intelligent Battery Saver which isolates the battery if draining to below 12V or so.
denman is offline
post #6 of 30 (permalink) Old 12-02-2009, 07:34 PM Thread Starter
Beefstick's Avatar
The lights dim while its running at an idle, and every once in a while my blinker will make my dash lights and radio flicker.
denman, what make is the heavy truck battery you use?
___________________________________________
2014 3500 CCLB Tradesman, HBS Levelled, Deleted with EZ Lynk tuning by Starlite Diesel
92 w250, auto, diy-4"lift, diy bumpers, 330K+miles
post #7 of 30 (permalink) Old 12-02-2009, 11:53 PM
90powerram's Avatar
I got a good quality group 31, no problems starting even after running a camper for the better part of the week, including running the electric boat motor.
But...you should figure out any possible wiring issues before blaming the batteries 100%.
2002 Ram 2500 24V 6-spd, 4" exhaust & AFE intake
90powerram is offline
post #8 of 30 (permalink) Old 12-03-2009, 12:04 AM
440trk's Avatar
Are you sure about that? To the best of my knowledge, if you hook them in parellel (pos to pos), that would make it a 24v system?
Mike(440trk)
91 W250 LE ~235k miles, 727, 3.07's w/limited slip rear
440trk is offline
post #9 of 30 (permalink) Old 12-03-2009, 12:07 AM
90powerram's Avatar
click ->Connecting Batteries in Series or Parallel
post #10 of 30 (permalink) Old 12-03-2009, 12:11 AM
GeneralC's Avatar
thats what it says in my buddies handbook at school to about connecting batteries. it was purty neat actually reading all about it. but yes im positive that connecting parallel keeps 12voltage and doubles cranking amps
GeneralC is offline
post #11 of 30 (permalink) Old 12-03-2009, 12:17 AM Thread Starter
Beefstick's Avatar
You want your batteries in parallel to double amperage with the same voltage, series doubles the voltage with the same amperage.
post #12 of 30 (permalink) Old 12-03-2009, 12:23 AM
richard.bessey's Avatar
2nd on that
2nd on that, parallel doubles amps, series doubles volts.
I got 4 batteries setup in parallel on my 12 volt solar system.
Check your grounds and other connections, having 2 batteries shouldn't case any more problems then having one.
Have you replaced altenator/volt regulator?
Stock 4X4 1992 Dodge Cummins Diesel
Manual 5 speed, regular cab
With a hundred thousand and something miles - and still runs great
richard.bessey is offline
