Old 11-08-2009, 08:30 PM   #1 (permalink)
thatoldodge's Avatar
Angry heater core
well i just about finshed up my heater core today, what a pain , took me about 4 hours to get it out,cleaned the hell out of everything it was a mess,got just about everything back together today!!!!
'93 d-350" p-pumped,no plate,2095 rack plug,5x16 custom sticks,o-ringed head,laser cuts,twins in the making 12mm arp studs,6in miter cut stack,4k gov,60lb valve springs,3in ic,build trans,auto meter gauges,
(CUMMINS is the ,Best, forget about the rest!! )
thatoldodge is offline   Reply With Quote
Old 11-16-2009, 02:47 PM   #2 (permalink)
denman's Avatar
Your procedure would be about identical to mine when (not if) the job becomes necessary. Any words of advice you wish to share? ....
1993 D350 DRW, Getrag G350, 760,000 km, CB, Sirius Sat radio, flat deck with headache rack.
denman is offline   Reply With Quote
Old 11-16-2009, 07:49 PM   #3 (permalink)
you dont have to remove the hole dash,remove glove box,there is 6 hold down nuts on the fire wall that hold to heater unit in. i just loosened up all the dash screws an get it movein around,i got a buddie hold up on the dash an i wiggled it out. just take your time an pay attention to where all the vaccum lines go!!!
