| 89-93 Non-Powertrain Discussion of 1st Gen. Topics Not related to the Powertrain...NO ADVERTISING |
any ideas on how to
Trying to get the upper front spring mount bolts out of the springs/bushings....they will not budge!! I have tried to spin them with up to an inch impact!! Still wont come out...any ideas? Should I just try to burn them out with a torch and then buy some new ones? will it hurt the springs by doing this? I don't know if you can still buy new stock bushings or not...seems like this oled 1st gen stuff is getting harder to get parts for at the dealers? |
#2 (permalink) |
1ST GEN MODERATOR
![]() Join Date: Nov 2007
If your talking about the front spring eye bolts. Take a 4.5" grinder. Install a thin cutoff wheel on it. There should be enough room for the cutoff wheel to go between the spring and the mounting bracket. Cut the bolt completely threw. Then replace the spring eye bushing if your going to reuse the spring. The dealer should be able to get new bushing. I would check NAPA also. I bet they can get them. If NAPA doesn't list it by model. Give them measurements of the old bushing. I bet they can find them that way.
93 W350 w/duals, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, Super HX40/16, auto(G56 soon), 3:07's axles, 2" skyjacker lift, B&W flatbed |
#3 (permalink) |
Bathed in Diesel
![]() Join Date: Apr 2006
I used a 6 foot cheater pipe and wedged the wrench in the frame to hold the backer. Once I got it spinning I took off the backer wrench and bumped the nut with a hammer while twisting the bolt. Kept working them out that way until I got it flush then used a punch. I got the new bushings installed at a spring shop, only 30 some dollars. Saves having to get a new bolt. Mine had 215k on it when I did it summer of last year.
3rd Gen. 06 Quad cab 3500 4X4, manual 2nd Gen. 97 Ext. cab 3500 4X4, manual slightly modded 1st Gen. 93 W350 4X4, manual, my farm truck... I'm seeing a pattern here |
#4 (permalink) | |
89 W-250 Flatbed 5 speed, cummins reman(95) non-I/C, 4" turbo back, AFC tuning. Fuel pin ground. More to come. Warming the globe since 1989
