Old 11-04-2009, 08:49 PM   #1 (permalink)
Need some info on the 1993 dodge
Hey guys Ive been looking for a cummins for quite a while and have ran across a 93 4x4 with the x cab and the manual transmission. Just wondering if you could tell me the kind of manual tranny that is he said it was a 4 spd? also what kinds of gear ratios for the axles were provided? any other info would be greatly appreciated
Thanks
Rosey42 is offline   Reply With Quote
Old 11-04-2009, 08:54 PM   #2 (permalink)
dieselfreak01's Avatar
a 93 doesnt have a 4 speed or i have never heard of one, the axles are most likely 3.54 but possibly 4.11, the tranny just about has to be a g360 "getrag". o and welcome to the forum
'93 d350 drw auto 167000 on the odometer and still running strong, 3.50 gears, ext cab soon to be 5" dp back exhaust
proud member of the OHIO COAL ROLLERS
dieselfreak01 is offline   Reply With Quote
Old 11-04-2009, 09:22 PM   #3 (permalink)
how are those trannys compared to the nv4500?
Old 11-04-2009, 09:30 PM   #4 (permalink)
from what i understand they are pretty reliable for everyday use and handle decent power. it will need to be over filled by a quart if i remember correctly
Old 11-04-2009, 10:25 PM   #5 (permalink)
Ok so how are they for commuting use will they motor just be screaming on the highway and milage down the hole? also the truck im lookin at has 280000 miles on it for 2000 bucks...any comments questions concerns?
Old 11-04-2009, 10:38 PM   #6 (permalink)
well depending on your right foot and the axles you should see decent mileage empty prolly around 16-18. as far as the truck the price seems pretty decent depending on what it looks like and how it was taken care of. the mileage doesnt scare me at all just be mindful of ball joints or king pins and the various wear items
Old 11-04-2009, 11:32 PM   #7 (permalink)
ok thanks i really appreciate the info ill go check the truck out tomorrow ..apparently its from utah so it shouldnt be too bad of a body.
Old 11-04-2009, 11:38 PM   #8 (permalink)
grizzly_man07's Avatar
just ask the guy who is salin it what rear end it has in it. he should know
91 d250, pump maxed. 1/8 in bump timing. BHAF for Freightliner. POD's. HX35 on the way. then puttin this baby on Meth single stack "rollin coal"
grizzly_man07 is offline   Reply With Quote
Old 11-05-2009, 12:02 AM   #9 (permalink)
JNDcumminscowboy's Avatar
280,000k bro thats just broke in im pushing almost 400,000k just make shur you change your fluids whn they need to be and put some injector cleanor in like twice a month it will run like a champ for as long as you own it what do you have planed for it
''1991 w250 LE 4x4 5 speed non Ic 3'' off the turbo 6'' tip'' pump turned up! Alot more "COAL ROLLING''
JNDcumminscowboy is offline   Reply With Quote
Old 11-05-2009, 02:42 PM   #10 (permalink)
Idk definetly wanna get some more power out of it, exhaust, tires, paint job maybe down the road. Just will use it for commuting, pulling a trailer around, have some fun with it...
Old 11-05-2009, 09:24 PM   #11 (permalink)
denman's Avatar
Well maintained Cummins with that mileage usually still have the honing marks on the cylinders. As was said there are the usual wear items, belts/hoses/tires/brakes, but the expensive basics are pretty bullet-proof if driven decently. The Cummins are legendary for long-life and good fuel economy , .... enjoy!
1993 D350 DRW, Getrag G350, 760,000 km, CB, Sirius Sat radio, flat deck with headache rack.
denman is offline   Reply With Quote
Old 11-06-2009, 02:00 AM   #12 (permalink)
Old 'n Rusty's Avatar
One of the guys on this forum turned up his engine and blew his head gasket. He had over 500,000 on the clock. He was stunned to find that there was no ridge on his cylinders and the cross hatching looked like new.
Our engines are industrial units. They are classed as medium-heavy and can push a heavy commercial truck for 200,000 miles at wide open throttle. In a pick-up truck a cummins should last for over a million miles.
91 (08-90) D250
5sp 2wd 497k VE 'adjusted', 3200 spring, Pyro, boost, 3.54 ,:thumbsup KN, 1\8" timing bump, 25mpg city 30mpg hiway 20mpg towing 6k 5'er
R60/7, Volvo 245 GL, f150 4x4 5 spd, Ram 318, MPG's are in Imp gal's
Old 'n Rusty is offline   Reply With Quote
