Old 11-01-2009, 09:52 PM   #1 (permalink)
firdtgen1's Avatar
radio question
im sure there is alot of questions about the radios. but mine dont work, it works now and then and thats it. same thing with my dads old 1990. is it the radio that is the problem or the wireing, seems to be a common problem whatever it is.
also does any body know where to get a replacement radio for these
1993 cummins, 16cm housing, 3 turns, pin ground, starwheel maxed, 4'' exhaust, custom intake, piston lift pump, dtt converter, shiftkit (new era 370, denny t, coming soon)
firdtgen1 is offline   Reply With Quote
Old 11-01-2009, 10:10 PM   #2 (permalink)
1ST GEN MODERATOR
Philip's Avatar
Its the radio. Our trucks shake them apart. I have went threw 2 in my truck. A friend has went threw 4 radio's across the 4ea 1st gens he has had.
Any radio out any model Dodge will work up untill about 98 when the rounded front radio's came out.
The later model radio's had seek buttons on them. If you move around a lot in strange areas. That seek button is nice for finding chanels.
Old 11-02-2009, 07:40 AM   #3 (permalink)
firdtgen1's Avatar
ha ha, thanks, guess ill be getting a new radio
Old 11-02-2009, 10:49 AM   #4 (permalink)
denman's Avatar
I got my radio out of an 88 New Yorker, ... the block terminals all matched and it's better than the radio it came with
1993 D350 DRW, Getrag G350, 760,000 km, CB, Sirius Sat radio, flat deck with headache rack.
denman is offline   Reply With Quote
Old 11-02-2009, 06:20 PM   #5 (permalink)
Gatekeeper's Avatar
I got my radio out of a 96 Minivan. Has CD/Tape/AM/FM. All the pligs matched. I"ve also had all 4 speakers fail in the last 2 years. Replace those when you replace the headend.
90 250 2wd auto Bone Stock.
Gatekeeper is online now   Reply With Quote
Old 11-03-2009, 10:33 PM   #6 (permalink)
James-93-12valve's Avatar
i got the stock one out of my truck
93 d350 5spd 4inch exhaust to a 6inch tip
James-93-12valve is offline   Reply With Quote
Old 11-03-2009, 10:52 PM   #7 (permalink)
gear jammer 91"'s Avatar
In my work truck when the radio turns itself off, I've found that if I turn it off and on repeatedly it will actually turn back on eventually, and work for a while longer.
04.0 HO QC 4x4 LB auto transgo VB, stock, for now
Sold 91 now intercooled W250, 388HP 923TQ on #2 only 436HP 968TQ on meth
Work Truck, 93 W350 LE Dually 5Spd almost stock
gear jammer 91" is offline   Reply With Quote
Old 11-04-2009, 12:32 AM   #8 (permalink)
Gatekeeper's Avatar
I'd give the stock AM/FM to you for the price of shipping.
Old 11-05-2009, 11:30 AM   #9 (permalink)
Get an after market one. The stocks ones make terrible sound quality
93 3/4 ton 5_speed CUMMINS. Star wheel all the way down. Smoke screw tightened.Denny t fuel pin. 100 horse injectors Proud Contributor to Global Warming!!!!!
pitman is offline   Reply With Quote
Old 11-05-2009, 08:12 PM   #10 (permalink)
1ST GEN MODERATOR
Philip's Avatar
Lets see. Most of these trucks don't have a muffler. These trucks don't have much sound deadner. It has a noisy B series cummins and you want to talk about sound quality from the stock radio.
Old 11-05-2009, 09:09 PM   #11 (permalink)
denman's Avatar
Good point, .... I've been surrounding the cab with sound insulation, starting in behind the door panels when I put in the new weather stripping. The door speakers were dead so replaced them at that time. Next will be the transmission tunnel and something down the back of the motor on the firewall. My dog sitting in the back seat is going deaf so I can hear the radio!
