| 89-93 Non-Powertrain Discussion of 1st Gen. Topics Not related to the Powertrain...NO ADVERTISING |
odd sound
this smornin when i went to work and diddnt notice it but i had to haul about 800 pounds of aluminum for my boss and after i unloaded it i noticed a squealwhen im slowing down but i dont notice it when im stoped im thinking its either a bearing or my tranny please help i need assistance ![]()
93 d350 5spd 4inch exhaust to a 6inch tip
#2 (permalink) |
1ST GEN MODERATOR
![]() Join Date: Nov 2007
check your u-joints.
93 W350 w/duals, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, Super HX40/16, auto, 3:07's axles, 2" skyjacker lift, B&W flatbed |
#4 (permalink) |
1ST GEN MODERATOR
A u-joint normaly gives a on/off squeal. I have seen u-joints that didn't make any sound. Then haul a load and get the suspension out of its normal range of movement. Then it starts making noise and doesn't stop. A fast test is go for a drive. Make it around 5 miles or so. Then crawl under the truck and fee the u-joint caps. A warm or hot u-joint is normaly bad.
| The Following User Says Thank You to Philip For This Useful Post: | James-93-12valve (10-31-2009) |
#7 (permalink) |
i've had them groan, grind and squeal, then burn out soon after. could be a brake as well. try to figure out where your hearing the sound from
| The Following User Says Thank You to diaric For This Useful Post: | James-93-12valve (11-01-2009) |
#8 (permalink) | |
![]() That is the best and easiest way to find out if its a you joint or not.And yeah James, a u-joint will make 1 he!! of a noise when they start to go out. And if i where you, ide hurry up and see if 1 is goin bad, and if it is and the squeak gets worse, ide try not to drive it if you can keep from it. Trust me, u dont want 1 to give away at 70mph.
00' 3500 quad cab, with all kinds of goodies,TOTALED!!!! 8/3/09. ![]() ![]() ![]() ![]() ![]() New toy, 98 12v, 2500, 2wd ext. cab, 5spd, silincer ring mia, custom cut #0 fuel plate, slid forward, starwheel cranked up, autometer guages, FBD 5" straight, more to come |
| The Following User Says Thank You to road hammer For This Useful Post: | James-93-12valve (11-03-2009) |
#10 (permalink) |
There are a couple of things which have caused squealing on mine. One was the steady bearing. Another was a broken retainer clip on the front brake pads which let them rub against the inside of the rim. Another was a worn out wheel bearing. Test the steady bearing by touching it after a drive. It can get quite hot. It is the inner rubber mount which squeals when the bearing starts seizing. This can go on for a long time. The bearing can seize and then release many times before everything comes apart. It is a good idea to check it early.
91 (08-90) D250 5sp 2wd 497k VE 'adjusted', 3200 spring, Pyro, boost, 3.54 ,:thumbsup KN, 1\8" timing bump, 25mpg city 30mpg hiway 20mpg towing 6k 5'erR60/7, Volvo 245 GL, f150 4x4 5 spd, Ram 318, MPG's are in Imp gal's |
