Old 10-26-2009, 12:50 AM   #1 (permalink)
rmauto1's Avatar
thinking about new tires
Ok, so I'm thinking about putting a set of 255/85R16 tires on my 93 W-250. Are any of you guys running them on your trucks? If you are, I would love to see some pics, to help me decide.
rmauto1 is offline   Reply With Quote
Old 10-26-2009, 12:55 AM   #2 (permalink)
im in the same boat. what tire u looking at? i think im gunna go with cooper st. its only 8 ply but i like the look of the tread.
1993 W250 5 speed, full 3.5" exhaust, asa intake, boost pyro gauges, custom front bumer with 12,000 pounds warn winch. soon to be installed : bosch 190's, south bend 350hp clutch, Governor spring
finny is offline   Reply With Quote
Old 10-26-2009, 01:01 AM   #3 (permalink)
rmauto1's Avatar
I'm thinking either the cooper's, or the toyo m-55. Called on the toyo's on thursday... they are on national backorder I really kinda want 10 ply's. I'm really hoping that some other guy's are running this size, and have some pics.
Old 10-26-2009, 06:50 AM   #4 (permalink)
I just took off a set of spent 255/80 BFG Mud Terrains. The tires were only D rated and wore out pretty quick, they only went about 20K before they were bald. They are way to soft for the weight of the Cummins IMO, the ride was terrible, traction in the rain sucked and ice was an excersize in keeping my underwear clean. I replaced them with some 305/70 E rated Firestone Destination AT`s, a HUGE improvement in all areas. I would definitely go with an E rated tire. Heres the only pic I have of the truck with the 255`s
93 W250 CC, POD`s, pump tweaked, 35/40, 4in & BHAF
chrislib is offline   Reply With Quote
Old 10-26-2009, 07:39 AM   #5 (permalink)
ZSkibo's Avatar
Chris, you have any lift or are you stock with those 305's? I ask because I'm currently running 285/75R16 BFG's but am going to a set of Dunlop Maxxtraction E rated 305's in a few weeks and wanted to make sure they'd fit ok. I'd get 315's as I plan on adding a 2" lift this winter but I don't think they'll fit the truck 'as-is'.
92' W250, rhino liner bed+cab. Pump bombed: timing 18*, AFC out, #366 spring, POD's, #60 exh springs, 2ndGen piston pump (@18psi), BHAF, HX35/40 (60/60/12), 4" turbo back 6" stack, full gauges, Banks engine brake, onboard air, train horns!
ZSkibo is offline   Reply With Quote
Old 10-26-2009, 12:54 PM   #6 (permalink)
The PO had an add a leaft put in and the springs re-arched but it has settled some since I bought the truck (5 years ago approx). With the rims on it and the 305`s I had to remove the front flares as the tires were catching on them and starting to damage the bottoms of the fenders. Without the flares there has been no rubbing. I think 305`s would fit/rub less or not at all if they were mounted on factory rims due to the offset and backspacing. Many aftermarket rims put the tire too far out wich is what is causing the rubbing on my truck.
Old 10-26-2009, 05:43 PM   #7 (permalink)
powerbrake's Avatar
i am running e rated firestone destination m/t's. theses are 285 75 16. i have been looking for a new set for the front end this winter and i've about sold myself on goodyear wrangler duratrac. check these out before you buy.
92 4x4, fuel screw turned in all the way, starwheel dropped to the bottom, 40 hp injectors, machined pin, detroit locker lets me smoke 'em evenly. auto meter pyro.
God Bless Our Country and Damn The Goverment
powerbrake is offline   Reply With Quote
Old 10-26-2009, 07:05 PM   #8 (permalink)
I just put a set of Wrangler Dura Trac 285-75s on, e rated. so far so good, one short jaunt offroad thru some fields, no problems. Onroad smooth and quiet. Love the look of the truck with them on too, nice sidewalls, nice tread pattern
92 W250, InterCooled, 4.10, 5 speed, Amsoil filter, Borgenson shaft, 285-75=16 Goodyear Dura-Traks
bouts21 is offline   Reply With Quote
Old 10-26-2009, 08:12 PM   #9 (permalink)
i have 255 85 bfg muds on mine seem fine to me they came on the truck they would look great but the truck has fender flares and it looks stupid with a narrow tire and flares without the flares they would look great. seem to perform just fine i want to go to alarger tire for looks mostly. i was trying to find this size tire for winter tires but not much luck.
92 extended cab 4x4 230000km, 2 inch lift, b.d.exhaust brake, banks power pack (intercooler turbo) 3'' sraight pipe, boost pyrometer oil temp gauges and tachometer. workin on installing b.d. fuel pin and a gov. spring and a few pump mods
MOUNTAIN MILLWRIGHT is offline   Reply With Quote
Old 10-26-2009, 08:17 PM   #10 (permalink)
rmauto1's Avatar
mountain millwright, do you have a pic or two of your truck with those tires on it?
Old 10-27-2009, 02:31 PM   #11 (permalink)
not realy just got it on the road havent had time to take any sorry. like i say would look good without the aftermarket fender flares. im putting 285 75s on next tire i buy otherwise its a good size tire
Old 10-30-2009, 03:55 PM   #12 (permalink)
i run the 255's in a local brand mud tire they never rub but the truck does have about 3" of lift .
lopez dodge is offline   Reply With Quote
