Old 09-14-2009, 08:45 PM   #1 (permalink)
lance0730's Avatar
vacuum pump leaking....
from right around the connection to the back side of the timing case. easy fix or something to worry about? is it a seal or is this a major repair? (91 intercooled 4X4)
1996 3500: Full billet DTT, pac brake, #10,timing,AFC,3GSK,Raptor100,58/14 Hybrid,#60,lockup cntlr,3 piece,CFM
lance0730 is offline   Reply With Quote
Old 09-14-2009, 09:23 PM   #2 (permalink)
1ST GEN MODERATOR
Philip's Avatar
Thats just a gasket at that point. Clean it off and watch it closely. Most of the time its leaking around the seal closest to the power steering pump.
93 W350 w/duals, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, Super HX40/16, auto(G56 soon), 3:07's axles, 2" skyjacker lift, B&W flatbed
The Following User Says Thank You to Philip For This Useful Post:
lance0730 (09-14-2009)
Old 09-14-2009, 09:47 PM   #3 (permalink)
lance0730's Avatar
...wondering if my napa guy will know which seal. thanks man
Old 09-14-2009, 10:48 PM   #4 (permalink)
1ST GEN MODERATOR
Philip's Avatar
Most likely not. I haven't heard of anyone that has found that seal by itself yet. There is a place that sells reseal kits for these Vac pumps. I'll have to look around for a link. Its been a while sence I have seen it posted.
