hardwiring a tach - Dodge Cummins Diesel Forum
Old 01-28-2006, 06:59 PM   #1 (permalink)
swank's Avatar
hardwiring a tach
this is a link to a TDR thread that i followed and now have a tach that works great.
93w350. twins.
truck pics
swank is offline   Reply With Quote
Old 01-28-2006, 07:14 PM   #2 (permalink)
Is there any way for you to get us the info? There is a small message there:
Non members can only view the initial post on threads more than 5 days old. There are 21 additional replies on this thread that you could view if you were a member.
Tom
Tom05 is offline   Reply With Quote
Old 01-28-2006, 07:35 PM   #3 (permalink)
Super Moderator
I had to add a W-wire for my tach to work,here are basic instructions and some pictures.
First-remove alternator,and remove backcover, 3 small nuts, and 1 large nut which holds plastic wire guard. May have to pry gently.
Second-Then remove screw from stator wire.I made short jumper wire with an eye on one end and a spade connecter for easy removal. Double heat shrink on eye end for protection. Install on stator screw.
Third-Carefully trim back cover for wire passage. Install back cover,feeding wire thru cover. Install nuts and install alternator,wires, etc.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
Old 01-28-2006, 07:41 PM   #4 (permalink)
swank's Avatar
how much couldn't you see? all of it?
i just went through the tread and it looks like illflem brought all the pertinent info over.
93w350. twins.
truck pics
Old 01-28-2006, 07:52 PM   #5 (permalink)
All the non-members can see is the first post. I couldn't tell if there was more info or not after the first post.
Tom
Old 04-07-2006, 01:16 PM   #6 (permalink)
Ford conversions?
Hi all. How does one run a tach like an Autometer on a diesel. I have a large 5"" face telltale i would love to use.
My 5.9 is in a 91 Ford and I am using the Ford alternator. Will this work on it?
Any help would be appreciated, and thanx, or better yet how does one make the Ford factory tach work on a 5.9?
Thanx all.
Done.Almost, lol:93 5.9 cummins motor, hx35, hx55 twins, POD injectors, water to air intercooler, and air to air aftercooler, BOV, in-cab fully adjustable dual wastgates, alcohol/water injection, C6 full manual pullin tranny, Ford F350 1-ton 4x4 pullin machine. :thumbsup
seeker1056 is offline   Reply With Quote
Old 04-07-2006, 02:30 PM   #7 (permalink)
swank's Avatar
do you know what kind of signal it needs? the ones that we used were autometer ones from www.surpluscenter.com. cost of 19 bucks and meant to be run off the alt.
93w350. twins.
truck pics
Old 04-08-2006, 09:55 PM   #8 (permalink)
fordcummins's Avatar
seeker,
PM me or call me for details. I know how to hook up your factory tach to work or your autometer.
-JJ
(317) 847-4092
Tow rig: 93 dodge, 1st gen. IC.
Puller: Ford 3.0, rockwell, drop box, reverser. unknown motor
Smiths Bell and Clock = work
fordcummins is offline   Reply With Quote
Old 04-08-2006, 11:11 PM   #9 (permalink)
one_ton's Avatar
nice
way to go swank
thats a good tid bit f information. makes me want to hook my tach up!
Bob
SUPPORT OUR TROOPS
1990 W250, 727TF DEEP PAN
4" LIFT, 35" TOYO A/T's, AIR BAGS IN THE REAR
MILD PUMP MODS
1/8 TIMING BUMP, 2 TURNS ON SMOKE ADJ. SCREW
K&N AIR FILTER, AIR BOX MIA, 3 1/2" STRAIGHT PIPE, 4" TIP
265K AND GOING
2004 POWER STROKE IC TO BE ADDED.
MY FIRST BORN SON IS DUE MAY 31, 2006
one_ton is offline   Reply With Quote
Old 02-03-2007, 10:20 AM   #10 (permalink)
Upstate Bombers VP
PToombs's Avatar
Hey! That alternator looks just like mine!
Just for an update, Surplus center sold out of these Tachs about 3 weeks after I posted the wiring. I wonder why?
I'm glad Swank spread it around so everybody could use it. :thumbsup
Pete
'92 D350, sticks, air, pipes, 388 hp, 799tq
'97 2500, ECLB
PToombs is offline   Reply With Quote
Old 03-19-2007, 11:03 AM   #11 (permalink)
If your feeling hardcore and really bored.
Find an old mechanical tach and get an alternator tapped to mechanical drive convertor. Another option is to find a mechanical tach from a 4bt. I heard they are more rare then first gen tachs.
}{ead$hot zod is offline   Reply With Quote
Old 03-23-2007, 10:38 AM   #12 (permalink)
Jarbo440's Avatar
Does anyone know if the AMI tachs that surplus center has now will work off the alternator?
Jarbo440 is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2012, vBulletin Solutions, Inc.
