Old 07-04-2009, 07:58 PM   #1 (permalink)
scrambler500's Avatar
smoke ring tip
i heard of this tip you get that blows rings at idle does any one have one or know how to make it because it sounds sweet
92 W250 flatbed rebuilding with ppump twinturbo and air locker rear
scrambler500 is offline   Reply With Quote
Old 07-04-2009, 09:17 PM   #2 (permalink)
carolina1stgen's Avatar
never heard of it but sounds pretty cool
1990 w250 pump turned up straight piped 4in 2 bald bfg on the back and some fuzzy dice for the ladies
carolina1stgen is offline   Reply With Quote
Old 07-06-2009, 07:19 PM   #3 (permalink)
James-93-12valve's Avatar
same here hadnt heard of them sounds cool thou
93 d350 5spd 4inch exhaust to a 6inch tip
James-93-12valve is offline   Reply With Quote
Old 07-07-2009, 12:13 AM   #4 (permalink)
1bad93's Avatar
ive seen pulling tractors do it but thats account of the high compression
1993 dodge power ram le 4x4 5speed, 6in skyjacker 35in mickey tompson, 16cm turbo housing, afe cold air intake, ddp fuel pin, 4in down pipe 6inch turnout stacks,alot of pump work, bully dog boost and pryo pillar gauges.pods
1bad93 is offline   Reply With Quote
Old 07-07-2009, 04:26 PM   #5 (permalink)
AKturbo's Avatar
haha I thought this was a tip on how to blow smoke rings..
sounds kinna cool though
89 W250. A727 w/ 3.07s, starwheel bottomed, smoke screw turned out, fuel screw 3/4 turn from runaway, Timed 3/16", DennyT stgII, 366 spring, 12cm exhaust housing, Amsoil air filter, muffler gone, Isspro pyro/boost. G-end TC, 62/71/14 S300, 4" DP to 5" to single 7" miter coming soon when funds allow.
66 Charger, 440 mag, carter 4 barrel, modified cam
AKturbo is offline   Reply With Quote
