Old 07-01-2009, 08:41 PM   #1 (permalink)
steering wheel off center,how to turn it?
just wondering how to center the steering wheel i hit a cross ditch on my way down from hunting lastnight in the dark now the wheel is off center??? thnx alot guys
1992 ram250 4x4!
mrkhan is offline   Reply With Quote
Old 07-02-2009, 09:23 PM   #2 (permalink)
Gatekeeper's Avatar
Get an alignment. (Before you destroy your tires) Something got bent when you hit that ditch. (Or a tie rod end got pulled in it's sleeve)
90 250 2wd auto Bone Stock.
Gatekeeper is offline   Reply With Quote
Old 07-03-2009, 12:27 AM   #3 (permalink)
everything straight and drives like it did before so im thinking just pull the wheel and re-center it....any tech forum or how-to's on that? thnx
Old 07-03-2009, 10:49 AM   #4 (permalink)
89smurf's Avatar
If you re-center the wheel it will turn sharper one direction than the other. Get the alignment.
89smurf is offline   Reply With Quote
Old 07-03-2009, 04:08 PM   #5 (permalink)
Gatekeeper's Avatar
The wheel is keyed and will not fit in any other position.
Old 07-03-2009, 09:59 PM   #6 (permalink)
hmmm i dont even see how an aligment will fix it but i guess its my only option to give'er a shot
Old 07-04-2009, 12:47 AM   #7 (permalink)
Richie O's Avatar
A few things could have happened. The drag link may have bent, the tierods could have slipped or bent, the spring center bolt may have broke letting the axle slide back ( been there ) , or even break or bend the steering box mount or frame. I hit hard in my 89 a few years ago and tweaked the wheel a little. It has not affected tire wear so I assume I shortened the draglink in my case.
89 dodge 3/4 4x4, A727 ,3.07 gears, factory L S , powerstroke intercooler, S300, stans exaust with stainless tailpipe, fuel power screw turned?, fuel pin turned to deepest, 3 turns smoke screw, 1/2 turn down on starwheel. 93 W250 ex cab, 6X16's, 60 GDS, rag
Richie O is offline   Reply With Quote
Old 07-04-2009, 02:09 AM   #8 (permalink)
yea it just seems weird that i can let go of the wheel on the freeway and it tracks straight no pull no vibrations so i have no clue
Old 07-04-2009, 11:03 AM   #9 (permalink)
Begle1's Avatar
Couldn't you just adjust both tie rods the same distance in the same direction? That's all you're going to end up doing in an alignment, isn't it?
2017 Fiat1600 with 1.4 liter McDonalds V-twin engine and Ikea transmission.
Begle1 is offline   Reply With Quote
Old 07-04-2009, 12:23 PM   #10 (permalink)
Richie O's Avatar
As long as it is in fact still in line before you start. I had a truck a few years ago that would bald tires in a couple thousand miles but ran straight and true. My buddy crunched his car once and drove it for a month with the tires squealing it was so out of line. You could hear him coming.
Old 07-05-2009, 05:15 PM   #11 (permalink)
I had a tie rod end go bad in my W350. I replaced it, and turns out I didnt get the TRE in as far as the other one. My wheel was off center, but it wandered like a drunk sailor on shore leave, too. I measured the toe, and it was actually toed OUT about 1/4". I adjusted the toe so it was toeing in about 1/16", and it now tracks straight and true.
Mark the center of your tires, and get a helper to measure the distance between the centers. The front should be closer than the rear (toeing IN). I dont know how much difference there should be, I just took a reasonable guess on mine and will do the math, converting degrees to inches someday.
I would check everything under the truck and look for bent stuff. These trucks are tough, but not quite bullet proof.
Daniel
92 W350 xcab LE, 5spd, 3.54s pump tweaks, piston lift pump, 60mm/ 16cm turbo. plain tailpipe with muffler. For sale
dpuckett is offline   Reply With Quote
Old 07-05-2009, 07:52 PM   #12 (permalink)
Richie O's Avatar
If I do a poor mans alignment I Jack up the truck, Spin the wheels and make a line in the center of the tread on both ( as dan said ), then roll the truck forward a couple feet to " load " the tierod ends ect. I then measure the front and back. I set them up at 1/8 inch or there abouts toe in.
