Old 08-26-2008, 03:07 PM   #383 (permalink)
Diesel-Dan
FASS Tech Dept.
Diesel-Dan's Avatar
Originally Posted by bcollin3 View Post
I need some help guys, my fuel pressure on my Edge moniter has been reading 0 for a while and I thought it was a bad sensor. I called Edge and they sent me a new one. Problem is it still reads 0psi. Called Edge again, guy on the line gave me a few things to do and determined that it was not the Edge and imformed me that my fuel pressure was indeed 0psi. I thought that my truck wouldn't be able to run lilke that? Anyway, I am going to put a machanical gauge on it and see what it reads as soon as I get home. My question is, What could be causing this? The guy at Edge said that my FASS filters may be clogged? He said that my truck was starving for fuel, but I doesnt seem to be still runs strong, only difference is my EGTs and engine temp have been a little hotter than normal. Any other ideas?
thanks,
First off....quit driving the thing until you figure out what is going on! Unless you have an idle $1200.00 just sitting around.
You need a mechanical gauge to double check that setup.
Do you have the FASS (Unit with 2 filters) or HPFP (Just the pump)? IF you have the FASS you can open the fuel door and listen for return fuel. The only way you would have fuel returning is if you had pressure at the injection pump. Quick easy test for pressure.
Let me know what you find...
Dan MacDonald
www.FASSRide.com
2001 2500, 4x4, Con OFEed, TBK, AFE Stage II kit W/ prefilter and 4" cowl mod. , FASS 150/150, Mach 2's, Drag Comp,
Currently running on B-100
'02 Jetta TDI 5 Speed "Mini Me" 45-50 MPG
Diesel-Dan is offline   Reply With Quote
