Old 08-08-2008, 08:14 PM   #5 (permalink)
Hot Stuff
Smokin'
Hot Stuff's Avatar
Originally Posted by shooter_d View Post
Mine did that too. I got it aligned and the problem went away, so I don't know if you are having the same issue. My front passenger tire was wearing, but the driver side was fine. I think that has to do with the fact that the axle is pushed to the passenger side a little because the trackbar is now too short. Maybe you should try a drop bracket or adjustable trackbar?
Actually the front axle is pulled towards the drivers side cause the Track Bar is too short.
'03 Black 2500 QC/LB 4x4, 6 speed, BHAF, black H2's, 35" BFG MT's, B&W turnover, Juice w/ Attitude, 5" str8 pipe, BD lift pump, spin on filters, traction bars
Adam---Proud member of the OHIO COAL ROLLERS
Hot Stuff is offline   Reply With Quote
