Originally Posted by Jonathan Caro
I don't know about the kits, but NG coming into homes is a much lower pressure than propane (the b*st*rd gas as hank hill says). Hence the larger holes for gas stoves, heaters, and grills than propane.
I've rigged up crawfish boiling pots on NG and I only had to bore out the holes.`
Yep the line pressure into a house is much lower on NG than a propane setup due to tank pressure. But a CNG system's tank would house relatively high pressures.
1999 2500 4x4 Club Cab Sport. ADRENALINE/pulse , BHAF, FBD 150 sticks, full set of gauges, FP light, Holley Blue pump, 1/2" big line kit, Draw straw, 3" glasspack, TC lockup switch, Stealth VP plate, Heated WVO setup, poor man's 'pane setup, BD TC, BD VB, Billet input, Derale pan.
Parts to come: turbo and bigger exhaust, both seriously needed now!
