I have heard that the code listed is internal failure of the pump, and it's only a matter of time before it does fail. On the bright side of things, they have gotten increasingly cheaper since a couple of years ago, and if you post a wanted to buy thread on this forum, it's like pricematching at it's finest. A lot of the guys on here have bought and replaced them, so if there is a deal to be found, I'm sure someone can point you in the right direction. If it were me, I would not tow until it is replaced
98.5 3500 2WD dually 4:10's lAuto Meter fuel, boost, pyro, and trans temp lOne piece headlights+ LED's l5 inch mitre stacks lHX 40 l150 horse Coaltrain sticks l.093 tubes l Smarty lEdge Comp HOT lStage 2 snow kit lBHAF lBD pusher pump lAmsoil, engine+diff
