Someone will correct me if I am wrong, but I believe that the PO 216 code is really bad news, and usually means it's time for a new injection pump, as for the other, if the pump is causing that many problems, it might have trigered the other code??? Not to sure on that second one though. I'm sure that someone else will chime in here!!
98.5 3500 2WD dually 4:10's lAuto Meter fuel, boost, pyro, and trans temp lOne piece headlights+ LED's l5 inch mitre stacks lHX 40 l150 horse Coaltrain sticks l.093 tubes l Smarty lEdge Comp HOT lStage 2 snow kit lBHAF lBD pusher pump lAmsoil, engine+diff
