Old 08-04-2008, 08:17 AM   #8 (permalink)
Diesel-Dan
FASS Tech Dept.
Diesel-Dan's Avatar
Originally Posted by DART505 View Post
Well just a update for others that might have this problem. The factory fuel filter was the issue.All I use is Fleetguard (Cummins) fuel filters. This filter only had 2,600 miles and change on it! No water in the bowl,no sedimate in the housing,Standyne in the tank,so I do not know what gives? I have been working on Diesels sense the mid 70's so I am not a rookie.It just blows my mind the trouble shooting time thinking it was other issues.I now have the 17psi idle back and 10 psi WOT. I always put a fuel pressure gauge on the pumps or on the outlet but not this one.It will get one!My 200 FASS had a taped port on the last one I installed but do not notise if this one has one?
Thanks for the update.....I know i have been guilty of assumptions in the past that have bitten me in the rear....I would have thought the same thing with a new filter. BUT a better suggestion from me might have been check prefilter pressure. Im going to file that one away for the next time. Glad we are up and running!
Dan MacDonald
www.FASSRide.com
2001 2500, 4x4, Con OFEed, TBK, AFE Stage II kit W/ prefilter and 4" cowl mod. , FASS 150/150, Mach 2's, Drag Comp,
Currently running on B-100
'02 Jetta TDI 5 Speed "Mini Me" 45-50 MPG
Diesel-Dan is offline   Reply With Quote
