Old 08-04-2008, 07:57 AM   #2 (permalink)
Diesel-Dan
FASS Tech Dept.
Diesel-Dan's Avatar
Originally Posted by rufushusky View Post
Hi CF,
I am adding a P551311 water seperator to my set up...should I add this on the suction side or the pressure side of my Fass HPFP? TIA.
Im guessing this is the filter?
If its tighter than 100-150 microns....needs to go on the pressure side. Will have nothing but pressure issues if you put on the suction side of the pump.
Dan MacDonald
www.FASSRide.com
2001 2500, 4x4, Con OFEed, TBK, AFE Stage II kit W/ prefilter and 4" cowl mod. , FASS 150/150, Mach 2's, Drag Comp,
Currently running on B-100
'02 Jetta TDI 5 Speed "Mini Me" 45-50 MPG
Diesel-Dan is offline   Reply With Quote
