You'll wonder how you ever lived without it. Takes 5 minutes tops.
On my truck with power seats I removed the window breaker entirely and jumped from the load side of the seat fuse to the load side of the window fuse. Both the windows and seat are now powered though the same fuse.
Just a 2" jumper with a crimp on spade terminal on one end a a little insulation striped off the other is all you need. Stuff the striped end in female fuse holder then insert the fuse, spade goes on the load side where the window fuse used to be.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Both far from stock
