Incase any of you want to be able to use your windows with the key off , make a jumper wire to run from the power seat hot terminal , over to the power window fuse (my truck does not have the power seats) the seats are power all the time. Make sure you run the jumper to the supply side of the window fuse , not the load side , so the power is still fused.
Dad's 97 2500 2wd slt laramie, star wheel ahead , afc housing slid ahead. otherwise stock... 5 spd 285k
Mine- 95 2500 4x4, 47rh, Billet TC , shift kit, 285 timberline M/T. Bhaf intake w/ custom heat shield, 5" flo-pro ,147k. 10 plate, 191 dv's, Di Pricol pillar gauges, boost elbow, piers I/C boots timed at 17.5*
On the shelf - 3k gsk, grover air horns
coming soon- Tow mirrors, and Twins?
looking for - 97 or 98 reg cab (or ext cab short box in the 98)4x4 5 sp 12v
