I have the corsa from the engine back. great system, no noise in cab. the cat-delete pipe did not fit correctly --hits frame. If not deleting cat should work great even if you just buy the muffler. It's heavy duty all stainless. Suggest you call corsa and see if it will work with your pipes if you just want muffler. They use special clamps, I would question how well it would go together without entire corsa cat back set up.
