OK. So I changed out the injector pump for a remaned one straight from cummins. Also install a new cam sensor while I had the pump out. It helped but it will still die if I am in 4th or 3rd @2500rpm hit the exhaust brake let the truck slow down to around 1000 rpms push the clutch in then it will just die. It will fire right back up. If I tap the throttle before I push the clutch in it won't die. Any suggestions?
