Originally Posted by AEdude1971
your VP is most likely dead...or maybe your apps is out of adjustment...you still have a stock style lift pump??? if you do...those can't keep up with the aggressive fueling that the Edge uses...HIGHLY recommend a FASS or AirDog!!! especially if you plan on playing with your edge on setting 4 or 5....it will drain your stock lift pump to 2-4 psi if not 0psi...and that will kill your VP in a heatbeat....I've already been down that road and learned the hard way..... A new VP...and a FASS 95 HPFP later....17psi idle...and 10-12psi WOT...
hey i have a new edge juice with attitude being shipped to my house and i saw you said something about upgrading the lift pump due to the edge's aggresive fueling. i notice you recommend FASS or airdog. how much does this cost and how hard is it to install. any advice is appreciated. thanks!!
99 2500 cummins turbo diesel, 5" straight pipe, pillar gauges, KN intake, silencer ring MIA, edge juice with attitude, many more to come
