Originally Posted by Ram3500Dually
Light has nothing to do with viscosity. It set to some perimeters that were messed up from the factory. The later flashes addressed the issue. You can reset it by turning key to on position and pumping the go pedal to the floor and back three times then turning the key back off. If the light really did work to the vicosity of the oil then the light would turn right back on, but it doesn't. You should be good to go on the first oil change at 5000 miles.
the check engine light does not...I didn't state that...but the contact dealership for oil change does....and yes that is derived off of oil viscosity...and I have later flashes and still have the same issues.....this is talking with engineers to how this is set up.
08 laramie mega cab 6.7 some goodies. 07.5 laramie quad cab some things fell off
