Originally Posted by badasscatman
 Has anybody had there ac just quit working ? I was disconecting my tst as I am having Lift pump broblems after the unhook no ac or mirror heat .I suspect the buttons as all fuses and relays are good I also called tst and got no response . also I did not smell burnt wires and there is no code .also ac comp is hooked up and ok .helllllllllllllllllp
Glad you were able to get the pan!
I would check out by the a/c compressor. The wires going to the cutout switch can sometimes rub themselves bare. I think they will rub on the a/c line itself. Check this thoroughly. I went ahead and added split wire loom on mine to prevent them from having this problem. I have to wonder why your mirror heat would quit at the same time. Any possibility you unplugged something under your dash?
(Hey, if you want; PM me about that sd 33 sometime. That would be great if we could work something out!)
Originally Posted by deathspeaker
i have a 96 2500 auto trans 2wdrive with 91000 mi all stock? i am 2nd owner i just put in some 2stroke now it smokes why . what can i do to emprove the mpg i get around 19 hwy
How much 2 stroke did you use? I would think it would smoke if you put in more than a qt per tank full.....
How fast are you running to get 19? If your filters are all clean, and you drive as gently as possible, you may be at your highest mileage. For the best you want to run about 65 mph or even less......
06 3500 4x4 SLT 48RE Mega sized, Plus 2 micron fuel filter, Twin Frantz oil filters, Rokk CPS, BHAF, ARE shell, Well, it's up to 14+ MPG
and of course there's a list of wants!
73 1210 2x4 Int'l - patiently waiting to become a Cummins! 76 Scout - looking for a 4BT!
