Originally Posted by TheNatural31
You say you have it connected on top of the filter? I would connect to the schrader valve on the VP!! Thats the reading that is most important and if you are reading 11-12 pre filter you may need to upgrade that LP with the mods you have!!
I pulled the banjo fitting off the VP and there appears to be a spring with a check ball in that fitting, not sure what that was for, original plan was to drill and tap the banjo fitting for 1/8" pipe threads, however when I seen that I put it in the filter hole closest to the block.
Brad
