Old 07-14-2008, 09:51 PM   #5 (permalink)
mike uz
dezink24, well i am hoping it will be back together. i fired it up for the first time after the upgrades today, and it ran GREAT, but a little tranny prob. no drive. so i took the trans back out and discovered that i torn one of the front clutch seals when i put the pump assembly in . So i should have it back together around lunch tomarrow. and as for the rest of the truck ( the body ) its a little rough ,i didnt want to pull it out of the shop untill it was painted but what the heII its only a dodge.
:06 5.9 3500 sg.rear wh. 6 speed 4 dr LB 4x4 red edge juice w/A2 HOT 1995 2500 4x4 5.9l auto, Head studs,60#v.s.,head ported. super b special,BD exh. man. ,75Hp. ddp inj, 4000 GSK,larger holders and lazer cut DV, 18.5* timming ,home ground 100 plate.
mike uz is offline   Reply With Quote
