Originally Posted by ah64id
According to Baldwin the SAE standard changed in the late 90's. Prior to the change 2 microns was "testable", and was commonly used. When SAE changed the standard there was no way to measure 2 microns, 5 microns became the smallest absolute rating. It was found that most 2 micron filters on the old standard were 5-7 on the new standard, so some filters are even better but rated higher.
So what I gathered was that Baldwin and Fleetguard now report on the new standard... which is a change and why many refer to the filters as 2 microns... And Cat and Donaldson still report on the old system.
So the Baldwin BF7633 meets all the requirements of the 1R0750, and I can get the 7633 for about $4 cheaper, so thats what I will run...
It kinda annoyed me that companies are reporting ratings based on 2 standards... but they all filter about the same...
Interesting.....good stuff man!:thumbsup
04.5 Ram 2500 Reg Cab 4x4 5.9, 48re, AEM, Smarty, Banks High Ram,FASS HPFP, Boost/pyro/trans/FP/RP gauges, 5" Exhaust, Cat 2 micron fuel filter, Amsoil Bypass, Reese Hitch, Single Disc Converter w/ Strictly Diesel VB
1997 Fleetwood Prowler 26.5"
